440 Piston selection question #2648129
04/23/19 12:06 PM
04/23/19 12:06 PM
Oklahoma City, Oklahoma
MrMayhem Offline OP
MrMayhem  Offline OP
I somewhat recenlty bought a 72 Duster with a mostly stock 440 aside from a cam and typical bolt ons... I decided I wanted to do a quick tear down and do a budget rebuild that would include a few parts that I recently aquired. I have a set of ProMaxx Heads (Sidewinders) which are at 84 cc's, Harland Sharp 1.60 Rollers, Comp XE284 cam and a ported Eddy RPM intake. My question is since I am trying to do this on a budget, what pistons are a good bang for the buck? I have been looking at the KB236 or KB237 (not sure if the 237 will work with my heads being sort of a closed chamber). I am trying to acheive 10.5 or slightly better compression. I know the Speed Pro 2355's are a good choice for not much more money, my only concern is valve clearance as it appears they do not have much of a valve pocket compaired to other pistions. This motor will never see NItrous and once I complete my stroker motor the 440 bottom end will be placed in my truck after I top it off with my 452 heads.
Re: 440 Piston selection question [Re: MrMayhem] #2648138
04/23/19 12:19 PM
04/23/19 12:19 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Wiseco Pro Tru is a nice piston for the money, you will need to cut the deck an extra .020-.025 or so if you run an aftermarket H beam to get around 0 deck though. .05 below deck with a .039 gasket will put you right about 10.5 with an 80 CC head
Re: 440 Piston selection question [Re: GTX MATT] #2648145
04/23/19 12:34 PM
04/23/19 12:34 PM
MrMayhem Offline OP
MrMayhem  Offline OP
The heads have 84 cc chambers...
Re: 440 Piston selection question [Re: MrMayhem] #2648150
04/23/19 12:39 PM
04/23/19 12:39 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I like Icon's. I have a set of Speed Pro in a motor and they are HEAVY. Icons cost a little more but are lighter.
Re: 440 Piston selection question [Re: DusterKid] #2648154
04/23/19 12:44 PM
04/23/19 12:44 PM
Cab_Burge Online work
Cab_Burge  Online Work
Lighter is way better up You could swap the rods out to a decent set of forged H beam or I beam BB Chevy type (7.100 long) with a set of custom pistons but that does require grinding the rod journals down to the BB Chevy size 2.200 work thumbsI have that done on all my forged steel Mopar cranks along with having them offset ground to 3.90 stroke, more torque with the longer stroke and better parts up
Re: 440 Piston selection question [Re: Cab_Burge] #2648256
04/23/19 07:24 PM
04/23/19 07:24 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Call Glen at United Engine & Machine Co. They are, Icon, KB, Silvolite and diesel pistons. Glen is tech. and sales. Also my brother. No. 775-882-7790 ext. 159
Re: 440 Piston selection question [Re: MrMayhem] #2648272
04/23/19 08:26 PM
04/23/19 08:26 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
So its not clear what all you are doing to the motor. Are you having it bored and honed, rebuilt or new rods, and a re-balance?
Re: 440 Piston selection question [Re: GTX MATT] #2648359
04/24/19 08:11 AM
04/24/19 08:11 AM
an8sec70cuda Offline
iagree Hard to beat these for the money. A little over $400 WITH rings. Float em or press em, nice stuff. I have a set on a motor I recently built. Came in at -.018" deck height, block had a light skim cut on the decks.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 440 Piston selection question [Re: an8sec70cuda] #2648400
04/24/19 10:23 AM
04/24/19 10:23 AM
MrMayhem Offline OP
MrMayhem  Offline OP
Where did you find the Wiseco piston for that price? I dont see anything near $400...
To clarify, yes I will be completely rebuilding the engine, hot tank, magnaflux, bore and machine to achieve .005 piston to deck and balance
Re: 440 Piston selection question [Re: MrMayhem] #2648410
04/24/19 10:45 AM
04/24/19 10:45 AM
Marsh performance... mopartsracing.com
I believe they are about $420
CHIP
Re: 440 Piston selection question [Re: an8sec70cuda] #2648453
04/24/19 01:00 PM
04/24/19 01:00 PM
MrMayhem Offline OP
MrMayhem  Offline OP
I sent an email to Marsh, we shall see what he has to say. I see summit has them for $882.
Re: 440 Piston selection question [Re: MrMayhem] #2648464
04/24/19 01:32 PM
04/24/19 01:32 PM
Get-X Offline
Get-X  Offline
I really like the Icon pistons and have had good luck with them the last couple of engines I've worked on. I think they're around $600 a set.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: 440 Piston selection question [Re: MrMayhem] #2648472
04/24/19 02:01 PM
04/24/19 02:01 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Re: 440 Piston selection question [Re: MrMayhem] #2648474
04/24/19 02:14 PM
04/24/19 02:14 PM
Might be faster to call him (Todd Marsh).
Another option is the Speed Pro 2355 "six pack" pistons. Cheap on ebay, but don't come w/ the rings.
https://www.ebay.com/itm/SPEED-PRO-...-Flat-Top-for-MOPAR-440-030/253626889627
CHIP
Re: 440 Piston selection question [Re: an8sec70cuda] #2648501
04/24/19 03:10 PM
04/24/19 03:10 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Stock rod or aftermarket? Mine are about .022 below with H beams and a skim cut, but the aftermarket rods I've seen are actually .008 shorter than stock
OP Summit has for $526 with rings
https://www.summitracing.com/parts/wis-pts531a3/overview/
Re: 440 Piston selection question [Re: GTX MATT] #2648517
04/24/19 03:34 PM
04/24/19 03:34 PM
Stock LY rods.
CHIP
Re: 440 Piston selection question [Re: an8sec70cuda] #2648572
04/24/19 06:57 PM
04/24/19 06:57 PM
MrMayhem Offline OP
MrMayhem  Offline OP
I want thank those who suggested talking to Todd Marsh! He's gonna hook me up with the Wiseco pistons/rings!
Re: 440 Piston selection question [Re: MrMayhem] #2648697
04/25/19 08:04 AM
04/25/19 08:04 AM
Good deal! Todd's great to deal with.
CHIP
Re: 440 Piston selection question [Re: an8sec70cuda] #2648724
04/25/19 09:40 AM
04/25/19 09:40 AM
Get-X Offline
Get-X  Offline
If you can get the Wisecos for $400ish w/rings I doubt you'll find a better deal than that.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: 440 Piston selection question [Re: DusterKid] #2648793
04/25/19 11:35 AM
04/25/19 11:35 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I got the wiseco pro tru with rings through summit for 485. They have a 2.050 compression height. Great bang for buck.
