440 Piston selection question
#2648129
04/23/19 12:06 PM
04/23/19 12:06 PM
Posts: 114 Oklahoma City, Oklahoma
MrMayhem
I somewhat recenlty bought a 72 Duster with a mostly stock 440 aside from a cam and typical bolt ons... I decided I wanted to do a quick tear down and do a budget rebuild that would include a few parts that I recently aquired. I have a set of ProMaxx Heads (Sidewinders) which are at 84 cc's, Harland Sharp 1.60 Rollers, Comp XE284 cam and a ported Eddy RPM intake. My question is since I am trying to do this on a budget, what pistons are a good bang for the buck? I have been looking at the KB236 or KB237 (not sure if the 237 will work with my heads being sort of a closed chamber). I am trying to acheive 10.5 or slightly better compression. I know the Speed Pro 2355's are a good choice for not much more money, my only concern is valve clearance as it appears they do not have much of a valve pocket compaired to other pistions. This motor will never see NItrous and once I complete my stroker motor the 440 bottom end will be placed in my truck after I top it off with my 452 heads.
Re: 440 Piston selection question
[Re: MrMayhem]
#2648138
04/23/19 12:19 PM
04/23/19 12:19 PM
Posts: 5,161 CT
GTX MATT
CT
Wiseco Pro Tru is a nice piston for the money, you will need to cut the deck an extra .020-.025 or so if you run an aftermarket H beam to get around 0 deck though. .05 below deck with a .039 gasket will put you right about 10.5 with an 80 CC head
[Re: DusterKid]
#2648154
04/23/19 12:44 PM
04/23/19 12:44 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
I like Icon's. I have a set of Speed Pro in a motor and they are HEAVY. Icons cost a little more but are lighter. Lighter is way better You could swap the rods out to a decent set of forged H beam or I beam BB Chevy type (7.100 long) with a set of custom pistons but that does require grinding the rod journals down to the BB Chevy size 2.200 I have that done on all my forged steel Mopar cranks along with having them offset ground to 3.90 stroke, more torque with the longer stroke and better parts
[Re: GTX MATT]
#2648359
04/24/19 08:11 AM
04/24/19 08:11 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Wiseco Pro Tru is a nice piston for the money, you will need to cut the deck an extra .020-.025 or so if you run an aftermarket H beam to get around 0 deck though. .05 below deck with a .039 gasket will put you right about 10.5 with an 80 CC head Hard to beat these for the money. A little over $400 WITH rings. Float em or press em, nice stuff. I have a set on a motor I recently built. Came in at -.018" deck height, block had a light skim cut on the decks.
[Re: an8sec70cuda]
#2648400
04/24/19 10:23 AM
04/24/19 10:23 AM
MrMayhem
Where did you find the Wiseco piston for that price? I dont see anything near $400...
To clarify, yes I will be completely rebuilding the engine, hot tank, magnaflux, bore and machine to achieve .005 piston to deck and balance
[Re: MrMayhem]
#2648410
04/24/19 10:45 AM
04/24/19 10:45 AM
an8sec70cuda
Marsh performance... mopartsracing.com I believe they are about $420
[Re: MrMayhem]
#2648464
04/24/19 01:32 PM
04/24/19 01:32 PM
Posts: 614 Michigan
Get-X
I really like the Icon pistons and have had good luck with them the last couple of engines I've worked on. I think they're around $600 a set.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: MrMayhem]
#2648474
04/24/19 02:14 PM
04/24/19 02:14 PM
an8sec70cuda
Might be faster to call him (Todd Marsh). Another option is the Speed Pro 2355 "six pack" pistons. Cheap on ebay, but don't come w/ the rings. https://www.ebay.com/itm/SPEED-PRO-...-Flat-Top-for-MOPAR-440-030/253626889627
[Re: an8sec70cuda]
#2648501
04/24/19 03:10 PM
04/24/19 03:10 PM
Posts: 5,161 CT
GTX MATT
CT
Wiseco Pro Tru is a nice piston for the money, you will need to cut the deck an extra .020-.025 or so if you run an aftermarket H beam to get around 0 deck though. .05 below deck with a .039 gasket will put you right about 10.5 with an 80 CC head Hard to beat these for the money. A little over $400 WITH rings. Float em or press em, nice stuff. I have a set on a motor I recently built. Came in at -.018" deck height, block had a light skim cut on the decks. Stock rod or aftermarket? Mine are about .022 below with H beams and a skim cut, but the aftermarket rods I've seen are actually .008 shorter than stock OP Summit has for $526 with rings https://www.summitracing.com/parts/wis-pts531a3/overview/
[Re: GTX MATT]
#2648517
04/24/19 03:34 PM
04/24/19 03:34 PM
an8sec70cuda
Wiseco Pro Tru is a nice piston for the money, you will need to cut the deck an extra .020-.025 or so if you run an aftermarket H beam to get around 0 deck though. .05 below deck with a .039 gasket will put you right about 10.5 with an 80 CC head Hard to beat these for the money. A little over $400 WITH rings. Float em or press em, nice stuff. I have a set on a motor I recently built. Came in at -.018" deck height, block had a light skim cut on the decks. Stock rod or aftermarket? Mine are about .022 below with H beams and a skim cut, but the aftermarket rods I've seen are actually .008 shorter than stock OP Summit has for $526 with rings https://www.summitracing.com/parts/wis-pts531a3/overview/ Stock LY rods.
[Re: MrMayhem]
#2648697
04/25/19 08:04 AM
04/25/19 08:04 AM
an8sec70cuda
I want thank those who suggested talking to Todd Marsh! He's gonna hook me up with the Wiseco pistons/rings! Good deal! Todd's great to deal with.
[Re: an8sec70cuda]
#2648724
04/25/19 09:40 AM
04/25/19 09:40 AM
Posts: 614 Michigan
Get-X
If you can get the Wisecos for $400ish w/rings I doubt you'll find a better deal than that.
