Re: B1 Dove rocker arms
[Re: Dart451]
#2647990
04/22/19 10:13 PM
04/22/19 10:13 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I like the T&D individual shafts. I bought a new set and picked up a used set just in case they are ever needed. If the car keeps setting in my shop they should last forever. Lol
[Re: Dart451]
#2648083
04/23/19 09:37 AM
04/23/19 09:37 AM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The single shaft T&D’s will probably have valve spring interference problems with your springs.
[Re: Twostick]
#2648284
04/23/19 09:21 PM
04/23/19 09:21 PM
Posts: 667 IL
Dart451
IL
Is there anything special about the Dove shaft dimension wise?
Kevin Good question will do some measuring tomorrow
[Re: Dart451]
#2649077
04/25/19 10:45 PM
04/25/19 10:45 PM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
When we bought our first B1's, immediate and continuous rocker/pushrod problems in a modest performance engine. Bought T&D common shafts and zero problems after that. After that only used T&D's and experienced no problems.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#2649201
04/26/19 09:57 AM
04/26/19 09:57 AM
fast68plymouth
So. Burlington, Vt.
Just to be clear...... the problem the OP is having with the shaft sounds like it was self inflicted rather than a defective, or substandard part.
He’s been running those heads and rockers for years.
