B1 Dove rocker arms #2647975
04/22/19 09:55 PM
04/22/19 09:55 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Just broke a dove rocker arm shaft, on my B1 headed street car. Broke from user error I was in a hurry to move the car out of shop while waiting on new valve springs and just bolted the shaft on real fast without backing off the adjusters I been using them for years without a problem. Trying to decide on upgrading to t&d or just replace the shaft if koffels even has them anymore.
Is the t&d single shaft worth the effort or just go to the single shaft system?
Re: B1 Dove rocker arms [Re: Dart451] #2647990
04/22/19 10:13 PM
04/22/19 10:13 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I like the T&D individual shafts. I bought a new set and picked up a used set just in case they are ever needed. If the car keeps setting in my shop they should last forever. Lol
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: B1 Dove rocker arms [Re: pittsburghracer] #2647997
04/22/19 10:28 PM
04/22/19 10:28 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
The T&D paired shafts are the best I've ever used. Hold lash well. Easy to remove and assemble as well.
Doug
Re: B1 Dove rocker arms [Re: dvw] #2648006
04/22/19 10:46 PM
04/22/19 10:46 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
There was a used set I should of bought a few months ago will regret that.
They look got and if I was pushing engine harder would be a no brainer
Re: B1 Dove rocker arms [Re: Dart451] #2648083
04/23/19 09:37 AM
04/23/19 09:37 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The single shaft T&D’s will probably have valve spring interference problems with your springs.
Re: B1 Dove rocker arms [Re: fast68plymouth] #2648089
04/23/19 09:58 AM
04/23/19 09:58 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Good to know.
Will check the rocker arms later today and see if there is any bad ones might be a deciding factor also.
Anyone know if the pushrods will work going from dove single to the paired t&d?
Re: B1 Dove rocker arms [Re: Dart451] #2648092
04/23/19 10:03 AM
04/23/19 10:03 AM
So. Burlington, Vt.
So. Burlington, Vt.
T&D uses ball and ball.
Re: B1 Dove rocker arms [Re: fast68plymouth] #2648096
04/23/19 10:14 AM
04/23/19 10:14 AM
Nevada
merpar Offline
merpar  Offline
Nevada
Everyone I know runs T&D, I run them also. They will fit your application, ball ball or cup ball. Just tell them what you have , such as springs. And they will make to fit.
Re: B1 Dove rocker arms [Re: merpar] #2648106
04/23/19 10:41 AM
04/23/19 10:41 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
So different pushrods. Will call t&d to see what they can offer but guessing the length wouldn't be correct either.
This starting to cost some money that will teach me to get in a hurry. Do have a call in to koffels to see what a new shaft for the doves cost.
Re: B1 Dove rocker arms [Re: Dart451] #2648234
04/23/19 06:01 PM
04/23/19 06:01 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Is there anything special about the Dove shaft dimension wise?
Kevin
Re: B1 Dove rocker arms [Re: Twostick] #2648284
04/23/19 09:21 PM
04/23/19 09:21 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Kevin
Good question will do some measuring tomorrow
Re: B1 Dove rocker arms [Re: Dart451] #2648305
04/23/19 10:40 PM
04/23/19 10:40 PM
TEXAS
Panty Dropper Offline
TEXAS
If you are referring to Koffels B-1 Shaft Rockers? I have a set that I will sell. I went to T&D Years ago. I broke a shaft,, well the stud backed out and broke the shaft.. Never replaced the 1 shaft, but everything is still there... Also Scott still sells them..
Just curious, but what kind of work is needed to go with the paired system? and how about the Spray bar system??
Thanks,
Re: B1 Dove rocker arms [Re: Panty Dropper] #2648349
04/24/19 07:29 AM
04/24/19 07:29 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Think the t&d paired is just a bolt on system but require pushrod oiling or a spraybar.
I checked last night and looks like a factory rocker shaft is same diameter and hole spacing, only difference is no holes in shaft for spraying the pushrods. Since I have pushrod oilng plus the stock oiling I should be fine with just buying some new heavy duty shafts.
Koffels said they can make some just be a couple weeks.
Thanks for offer but I already have a used spare set but both shafts are tweaked so want to start with perfect straight shafts again.
Re: B1 Dove rocker arms [Re: Dart451] #2649077
04/25/19 10:45 PM
04/25/19 10:45 PM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
When we bought our first B1's, immediate and continuous rocker/pushrod problems in a modest performance engine. Bought T&D common shafts and zero problems after that. After that only used T&D's and experienced no problems.
Plynouth VIP '67 TT IC EFI
Re: B1 Dove rocker arms [Re: jyrki] #2649201
04/26/19 09:57 AM
04/26/19 09:57 AM
So. Burlington, Vt.
So. Burlington, Vt.
Just to be clear...... the problem the OP is having with the shaft sounds like it was self inflicted rather than a defective, or substandard part.
He’s been running those heads and rockers for years.
Re: B1 Dove rocker arms [Re: fast68plymouth] #2649218
04/26/19 10:40 AM
04/26/19 10:40 AM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Yes it was self inflicted whistling
The heads have been on car for 13 years, Normally I don't take a short cut but every now and then you have to learn a hard lesson
