Page 2 of 3 1 2 3
Re: Borgeson steering box [Re: MileHighDart] #2646494
04/18/19 02:46 PM
04/18/19 02:46 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by MileHighDart
Well, i can add a little info to this conversation.
I just installed a borgeson box in my '68 Dart
I decided to pull the trigger on this because of the slop in my original box, and the leaking became a big problem..
Purchased a unit from BAC, seems to be the newer style, its a one piece casting, meaning it doesn't have anything welded to it.
It is smaller and lighter, but I still had to bang on my headers in a new spot to get clearance for the Borgeson unit, (dougs headers).
Install went well enough, I used BAC's coupler. New box has absolutely no play in the center like my old box, it has a nice feel, nice and firm.
No slop, no leaks. Also installed a new Moog pitman arm when I did the box cause its the only component in front end that I had not replaced or upgraded yet.
The problem I'm having is the steering wont return to center by itself after turning. It returns somewhat, but slowly, and not all the way to center.
You still have to straighten up by turning the wheel back to center yourself. Kind of annoying to say the least.
BAC told me I probably didnt have enough caster. So I went though my alignment last sunday. When I first checked I had 3 degrees of caster. After some adjusting I managed to get 6 degree, thanks to my QA1 upper arms. Old box return to center great with 3 degrees.
But adding more caster didn't fix the issue. Maybe slightly better.
Sent an email directly to Borgeson, They suggested backing off the adjustment on the top of the box 1/4 turn and see if that fixes it.
Nope, tried 1/4 turn, and then another 1/4 turn, but the problem persists.
Just sent an email back to Borgeson again telling them the adjustment didn't work. We'll see what they say.
Welcome to the world of Borgeson close engineering where 90% is good enough. Next thing you'll hear is we've sold hundreds of these and you're the only one having a problem (we really do need a BS smilie) shake_head
Similar experience/ problems with Eddie Motorsports on their S Drive serpentine BB conversion.
Maybe I'm the one's thats wrong in expecting the "kits" to work without a bunch of hair pulling BS
twocents
Re: Borgeson steering box [Re: TJP] #2646581
04/18/19 06:59 PM
04/18/19 06:59 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree This kind of BS where parts don't fit, is one of the key reasons why I probably won't do another project. I swear, everything is at best only 80% or 90% correct. If it will even work at all. tsk
Master, again and still
Re: Borgeson steering box [Re: krautrock] #2646684
04/19/19 01:54 AM
04/19/19 01:54 AM
Lyons, CO
MileHighDart Offline
Lyons, CO
Originally Posted by krautrock
is it the photo or is there a bit of an angle at the coupler in the steering shaft?
Yes there is actually quite an angle difference between the shaft coming out of the box, and the steering column shaft
I emailed Bergman auto craft about this, his answer was that because the box is smaller
Than the original the angle is necessary, and his coupler is designed to handle the angle.
Re: Borgeson steering box [Re: MileHighDart] #2646830
04/19/19 12:57 PM
04/19/19 12:57 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I've been tempted to purchase and install ... and try the Borgenson box (and get it through BAC with their coupler, hoses, etc), primarily interested in the reduced weight (~10 lbs?)... but the ratio is only stated at ~14:1... whereas the T/A box with fast ratio long pitman arm (and the C-body longer idler arm... aka "fast ratio matching idler arm)... seems to be the faster setup for quickest steering response. I had my T/A box recently rebuilt by Firm Feel (Stage 3)... still to drive the car as its waiting for the new SB engine.
I've always wondered IF the longer "fast ratio" pitman arm would work with the Borgenson box... and what the ratio would become.. and the resulting steering effect. I want the fastest steering response. (Using a smaller diameter steering wheel also helps.... I use an 11.5" thick deep-dish padded wheel... works great!)
Re: Borgeson steering box [Re: Mopar Mitch] #2646879
04/19/19 03:36 PM
04/19/19 03:36 PM
AndyF Offline
AndyF  Offline
The fast ratio arms are quoted as changing the rato by 75% so 14:1 would turn into 10.50. I've never done it myself but that is what the math says. I think the fast ratio Pittman arm is available in both large and small sector.
I'm in the process of sorting out a Borgeson box for my '65 Coronet so I'm following along on this thread.
Re: Borgeson steering box [Re: AndyF] #2646911
04/19/19 05:24 PM
04/19/19 05:24 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
It seems to me that anything "faster" than 12 to 1 might be too twitchy, maybe even too much steering effort?
Re: Borgeson steering box [Re: Mopar Mitch] #2647558
04/21/19 01:10 PM
04/21/19 01:10 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Ok i will admit right a way that i dont have any experience with the Borgeson box.the fast ratio pitman arm or a firm feel box for that mather,but i will throw in a few thoughts from an outside osberver anyway,
The longer idler arm and pitmanarm will push your steering linkage rearwards and may create interference with your headers/exhaustpipes just one of those things that may be good to keep an eye on.
Also i dont know how those firm feel boxes "feel" but just getting away from that big "dead" spot around center that most stock boxes has should be a great advantage from the borgesonboxes from what i undertsand.
Re: Borgeson steering box [Re: 1Fast340] #2647578
04/21/19 03:23 PM
04/21/19 03:23 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've been daily driving my (1st gen) Borgeson P/S-box for about 6 years already with great pleasure.
Recently had the car on a circuit too which was great fun.
Re: Borgeson steering box [Re: BigBlockMopar] #2647628
04/21/19 08:34 PM
04/21/19 08:34 PM
AndyF Offline
AndyF  Offline
Sounds great, good to know you are enjoying it. I'm still rounding up the parts for my conversion. I was going to use the Saginaw pump but now I'm considering going with a late model Type II pump instead. I suppose if I'm going to make it modern I should go ahead and make it modern.
Re: Borgeson steering box [Re: AndyF] #2647643
04/21/19 09:31 PM
04/21/19 09:31 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I've considered this conversion too. Glad yo're doing it Andy. Be sure to make more than one set of pump brackets smile
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Borgeson steering box [Re: AndyF] #2647644
04/21/19 09:33 PM
04/21/19 09:33 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I've had my share of issues with a Type II pump, but they now seem to be resolved. I ended up going through one generic Speedway motors pump, one junk parts store pump before landing my PSC Motorsports pump that seems to be getting the job done. They are quite particular about their fluid, I use the recommended AC Delco power steering fluid, and nothing else.
PSC ball bearing "race" Type II pump with integral reservoir and a Borgeson box. I'd like to add the long arms to the box and idler, the steering is too slow for me. My pump mount design doubles as a torque strap mount as well. [final hose routing is not shown]
Screen Shot 2019-03-11 at 9.48.18 PM.png18901441_10212111705684490_570470973_o.jpg
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Borgeson steering box [Re: 71TA] #2648034
04/22/19 11:56 PM
04/22/19 11:56 PM
AndyF Offline
AndyF  Offline
Here is an old picture I have of a Type II pump. I didn't make these brackets but I don't know where they came from. Does anyone recognize them? I looked the other day for Mopar big block Type II brackets and came up empty.
Re: Borgeson steering box [Re: AndyF] #2648070
04/23/19 08:52 AM
04/23/19 08:52 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Damn. Those look nice.
Was it these guys?
https://www.bouchillonperformance.com/inc/sdetail/984/1005
Re: Borgeson steering box [Re: AndyF] #2648110
04/23/19 11:06 AM
04/23/19 11:06 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Possibly Unisteer ?? they have a setup that s very close except for the rear mount, the picture may be an earlier design ??
Unisteer LINK beer
Re: Borgeson steering box [Re: TJP] #2648118
04/23/19 11:26 AM
04/23/19 11:26 AM
AndyF Offline
AndyF  Offline
Yep, I think it was Unisteer. They sent me one of their rack and pinion setups back then to look at and they must have included a type II pump setup. I'd forgotten about the pump bracket but it sure looks like the same one. I'll order one to see how the new design works.
Re: Borgeson steering box [Re: AndyF] #2648286
04/23/19 09:24 PM
04/23/19 09:24 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Is there any benefit to going to a type II box over the Saginaw? I'm actually looking at buying a new pump this season and haven't had any luck with junk parts store boxes. Borgeson sells them and I just planned on get a pump from them to match the steering box. They're $350 though and for that I can get the brackets and type II pump from Unisteer.
Re: Borgeson steering box [Re: MileHighDart] #2648318
04/23/19 11:37 PM
04/23/19 11:37 PM
tucson az
frank Offline
frank  Offline
tucson az
The same for the box I put in my Charger. I'm using my Saginaw pump that I already had. Have not driven the car yet but just turning the wheel staticly I could feel a big difference.
Re: Borgeson steering box [Re: MarkZ] #2648330
04/24/19 01:18 AM
04/24/19 01:18 AM
AndyF Offline
AndyF  Offline
The Type II box is lighter and more popular with the aftermarket than the Saginaw pump. I also think it looks better. I can't tell you on performance since I don't have any experience yet with either box. I think the Saginaw pump works okay but it doesn't seem to be the hot setup for the road race guys. They all seem to be using the Type II pump these days. So for a street car I think the Saginaw probably works just fine. The Saginaw is also dirt cheap to buy and rebuild (if you have the proper tools). Personally I think I'll end up with the Type II pump on my car but that is because I'm more Mod than Resto. I already have the EFI, Porsche brakes, Toyota alternator, digital dash thing going on. Might as well keep it rolling with a Type II PS pump........
Re: Borgeson steering box [Re: AndyF] #2648584
04/24/19 07:39 PM
04/24/19 07:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
For those reading this and planning on using the type 2 pump, make sure to get a pulley that has a removable hub collar like a normal press fit saginaw pulley. The Unisteer pulley pictured above does not have the hub and is difficult if not impossible to remove once pressed on.
Also be aware that if you try to press the pulley on until it is flush with the shaft as usual, the back of the pulley will bottom on the pump housing mad panic
Can you say BAD DESIGN ??? beer
Re: Borgeson steering box [Re: TJP] #2648601
04/24/19 08:27 PM
04/24/19 08:27 PM
BDW Online content
BDW  Online Content
Love what Goody did, that bracket for the Gen 3 is sweet.
How do I get 1?
Page 2 of 3 1 2 3
