SB oil pump help #2647031
04/19/19 10:07 PM
04/19/19 10:07 PM
W. Kentucky
justinp61 Offline OP
W. Kentucky
Does anyone have a link or the specs for the rotor/gerotor clearances? I thought it was in the archives here but can't find it.
Re: SB oil pump help [Re: justinp61] #2647123
04/20/19 09:13 AM
04/20/19 09:13 AM
Pottstown, Pa.
sg1093 Offline
sg1093  Offline
Pottstown, Pa.
From a 1971 Service Manual, between outer rotor and pump body, more than .014, replace. Between inner and outer rotors, no more than .010.
Re: SB oil pump help [Re: justinp61] #2647257
04/20/19 01:49 PM
04/20/19 01:49 PM
Justin are you haveing a psi issue or just checking one on the bench?
Re: SB oil pump help [Re: RapidRobert] #2647296
04/20/19 03:50 PM
04/20/19 03:50 PM
W. Kentucky
W. Kentucky
Robert I'm checking the pump clearances while it's out. The pick up tube broke off in the pump so the pan is off and the pump is out. I think I'll ad a shim to the bypass valve while it's out, this engine is built pretty loose.
Re: SB oil pump help [Re: justinp61] #2647304
04/20/19 04:22 PM
04/20/19 04:22 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Clearance over the rotors - .004" max
Outer rotor to body - .014" max
Tip clearance between rotors - .010" max
These are max numbers for replacement. I would want them to be tighter on anything that matters. You can snug up the clearance over the rotors by facing the body with some fine paper on a smooth, flat surface. .004" is a big gap to be losing oil through.
Re: SB oil pump help [Re: CMcAllister] #2647328
04/20/19 05:36 PM
04/20/19 05:36 PM
W. Kentucky
W. Kentucky
Thanks guys. I have .0025" cover to rotors, .005" between the housing and outer and as marked in the images below.
Re: SB oil pump help [Re: justinp61] #2647383
04/20/19 08:39 PM
04/20/19 08:39 PM
How much depth on the scroll and rotor to the pump housing? work
Re: SB oil pump help [Re: Cab_Burge] #2647390
04/20/19 08:51 PM
04/20/19 08:51 PM
W. Kentucky
W. Kentucky
.0025".
Re: SB oil pump help [Re: justinp61] #2647396
04/20/19 09:01 PM
04/20/19 09:01 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by justinp61
.0025".
I think I would try to snug that up some. Give the cover a few swipes too, just to catch any burrs or high spots.
Re: SB oil pump help [Re: CMcAllister] #2647404
04/20/19 09:36 PM
04/20/19 09:36 PM
W. Kentucky
W. Kentucky
.0025".
I've already flat sanded the cover and will do the same to the housing.
Re: SB oil pump help [Re: justinp61] #2647569
04/21/19 02:31 PM
04/21/19 02:31 PM
use a figure 8 motion
