Re: SB oil pump help
[Re: justinp61]
#2647257
04/20/19 01:49 PM
04/20/19 01:49 PM
RapidRobert
Justin are you haveing a psi issue or just checking one on the bench?
[Re: justinp61]
#2647304
04/20/19 04:22 PM
04/20/19 04:22 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Clearance over the rotors - .004" max Outer rotor to body - .014" max Tip clearance between rotors - .010" max
These are max numbers for replacement. I would want them to be tighter on anything that matters. You can snug up the clearance over the rotors by facing the body with some fine paper on a smooth, flat surface. .004" is a big gap to be losing oil through.
[Re: justinp61]
#2647396
04/20/19 09:01 PM
04/20/19 09:01 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I think I would try to snug that up some. Give the cover a few swipes too, just to catch any burrs or high spots.
[Re: CMcAllister]
#2647404
04/20/19 09:36 PM
04/20/19 09:36 PM
Posts: 11,678 W. Kentucky
justinp61
W. Kentucky
I think I would try to snug that up some. Give the cover a few swipes too, just to catch any burrs or high spots. I've already flat sanded the cover and will do the same to the housing.
