Carburetor Synchronizer/Manometer
#2646867
04/19/19 02:54 PM
04/19/19 02:54 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Does anyone know where I can get a dual carb synchronizer, specifically for dual afb's? Dvorak Machine sells one, but I can't get a hold of them.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
Re: Carburetor Synchronizer/Manometer
[Re: RTSrunner]
#2647094
04/20/19 04:09 AM
04/20/19 04:09 AM
Posts: 562 Ohio
lockjaw-express
Ohio
Here is one for you...I made it, and works great!
BTW, I got the design off of the web somewhere...
[Re: lockjaw-express]
#2647113
04/20/19 08:37 AM
04/20/19 08:37 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
BTW, I got the design off of the web somewhere... Lockjaw do you have an Offenhauser dual quad there? Whats some specs of the car and engine? How does the manifold perform? Offenhauser is an interesting company.
Keep old mopars alive.
[Re: dvw]
#2647184
04/20/19 10:58 AM
04/20/19 10:58 AM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
I agree with no need for this tool. Been running dual carbs street car and racecar for over 25 years. Start with all 4 mixture screws the same number of turns and move all 4 the same amount. Doug Different intakes will make carbs perform differently. The signal will be different from carb to carb. Same intake with 2 different pairs of carbs will require a different tune. These carb sync tools are a very valuable toll to tuning dual carbs. As well as a single carb.
#2647218
04/20/19 12:10 PM
04/20/19 12:10 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
The tool on the top is what I have along with one cast aluminum reducer adapter As far as the Offy 360 dual carb intakes with dual carbs.on a wedge motor don't do that The other dual plane dual quad intakes are way better than those old flat Offys
[Re: Sammy]
#2647225
04/20/19 12:33 PM
04/20/19 12:33 PM
Posts: 9,835 MI, usa
dvw
MI, usa
I agree with no need for this tool. Been running dual carbs street car and racecar for over 25 years. Start with all 4 mixture screws the same number of turns and move all 4 the same amount. Doug Different intakes will make carbs perform differently. The signal will be different from carb to carb. Same intake with 2 different pairs of carbs will require a different tune. These carb sync tools are a very valuable toll to tuning dual carbs. As well as a single carb. So maybe we should build one that does all 8 individual throttle plates. Splitting hairs here. Doug
[Re: moparx]
#2647377
04/20/19 08:25 PM
04/20/19 08:25 PM
Posts: 562 Ohio
lockjaw-express
Ohio
Went to Fergussons Plumbing supply and bought the pieces. Just took a top ring gasket with me and this picture.
Also, bought the adjustable synchronizer off of ebay (popular item) for SU Carbs (British Carbs)...took that to the supply house too.
This is not my engine!
Mark
#2647515
04/21/19 10:52 AM
04/21/19 10:52 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Manometer. Isn't that what Rosie O'Donell uses to pick out what she/it is going to wear? HA!
Carl Kessel
