Two 71 B-Body LA plant questions #2645066
04/14/19 03:31 PM
04/14/19 03:31 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
I
Re: Two 71 B-Body LA plant questions [Re: RJS] #2645133
04/14/19 08:16 PM
04/14/19 08:16 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Re: Two 71 B-Body LA plant questions [Re: RJS] #2645173
04/14/19 09:27 PM
04/14/19 09:27 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Cooler should be there for power steering & 3.55 or lower gears.
As far as the fender tag & screws go, just put them back the way you found them if they had not been altered since no two cars are ever exactly the same to every minute detail.
Re: Two 71 B-Body LA plant questions [Re: Alaskan_TA] #2645177
04/14/19 09:38 PM
04/14/19 09:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
and....
If converting from manual to power steering, it becomes a custom build, not a restoration.
So you posted in the correct forum.
Re: Two 71 B-Body LA plant questions [Re: Alaskan_TA] #2645301
04/15/19 10:10 AM
04/15/19 10:10 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Originally Posted by Alaskan_TA
and....
