Trick to removing backing plate? #2644674
04/13/19 10:53 AM
04/13/19 10:53 AM
Myrtle Beach, SC formerly the ...
340wedge Offline OP
340wedge  Offline OP
I am in the process of rebuilding the front drum brakes, 1971 Plymouth. The bolts for the wheel cylinder are tough to get too because of the spindle so I am trying to remove the backing plate. I have all four bolts loose and can move the backing plate on the top but the bottom seems to bind and I cannot get it off. Any ideas? Thank you. up
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Trick to removing backing plate? [Re: 340wedge] #2644697
04/13/19 11:23 AM
04/13/19 11:23 AM
moparx Offline
moparx  Offline
if i'm thinking correctly, the bottom bolts are connected to the lower balljoint, which is connected to the lower control arm. if the assembly is hanging free, you would have the torsion bar applying tension to the ball joint. place a floorjack under the lower arm and apply tension. that should allow you to unbind the lower bolts.
please let us know how this works out.
beer
Re: Trick to removing backing plate? [Re: 340wedge] #2644704
04/13/19 11:35 AM
04/13/19 11:35 AM
Alberta
4mulaS Offline
4mulaS  Offline
Alberta
Probably just getting hung up on the threads a bit. Just keep trying, don’t use kid gloves on it. Treat it like a rental and it should come.r
66Scar
Re: Trick to removing backing plate? [Re: 4mulaS] #2644710
04/13/19 11:48 AM
04/13/19 11:48 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Might help to unscrew the brake hose from wheel cyl first, as it's probably that weird steel angled job.
Re: Trick to removing backing plate? [Re: moparx] #2644716
04/13/19 12:00 PM
04/13/19 12:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree Trying to remove the lower bolts through the steering arm under tension can be dangerous.
Re: Trick to removing backing plate? [Re: moparx] #2644724
04/13/19 12:36 PM
04/13/19 12:36 PM
340wedge Offline OP
340wedge  Offline OP
beerThank you MoparX, I put the jack under the control arm and it came right off! up
Re: Trick to removing backing plate? [Re: 340wedge] #2644875
04/14/19 12:02 AM
04/14/19 12:02 AM
AndyF Offline
AndyF  Offline
You are lucky you didn't hurt yourself. Might be time to invest in a FSM. If you knocked those bolts out of there while the torsion bar was under tension you could've been seriously hurt.
Re: Trick to removing backing plate? [Re: 340wedge] #2644987
04/14/19 11:33 AM
04/14/19 11:33 AM
moparx Offline
moparx  Offline
glad you got it off, and nothing [including you biggrin] was damaged !
beer
