Re: Trick to removing backing plate?
[Re: 340wedge]
#2644704
04/13/19 11:35 AM
04/13/19 11:35 AM
Posts: 835 Alberta
4mulaS
Alberta
Probably just getting hung up on the threads a bit. Just keep trying, don’t use kid gloves on it. Treat it like a rental and it should come.r
66Scar
[Re: moparx]
#2644716
04/13/19 12:00 PM
04/13/19 12:00 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
place a floorjack under the lower arm and apply tension. that should allow you to unbind the lower bolts.
Trying to remove the lower bolts through the steering arm under tension can be dangerous.
