A-518 (46RH) converter interchange #2642910
04/08/19 07:12 PM
04/08/19 07:12 PM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
I'm pretty sure that a non-lockup A-727 converter can be used in a non-lockup A-518 (46RH). AFAIK a post-66 A-727 has a 24 spline input shaft and the early non-lockup A-518 does too. So can someone weigh in and confirm/negate that the converters interchange?
Thanks!
Re: A-518 (46RH) converter interchange [Re: mrob] #2642946
04/08/19 08:24 PM
04/08/19 08:24 PM
A727Tflite Offline
A727Tflite  Offline
All 1967 and later non-lockup converters interchange between the large family transmissions.
Re: A-518 (46RH) converter interchange [Re: A727Tflite] #2643109
04/09/19 08:29 AM
04/09/19 08:29 AM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
Thanks for confirming Transman!
Re: A-518 (46RH) converter interchange [Re: A727Tflite] #2643354
04/09/19 06:22 PM
04/09/19 06:22 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Does the same hold true for the lock up converters?
- Stu Harmon
Re: A-518 (46RH) converter interchange [Re: feets] #2643364
04/09/19 06:37 PM
04/09/19 06:37 PM
Guitar Jones Offline
Yes, lockup to lockup except for V10 and diesel converters.
Re: A-518 (46RH) converter interchange [Re: Guitar Jones] #2643429
04/09/19 09:19 PM
04/09/19 09:19 PM
A727Tflite Offline
A727Tflite  Offline
All large family lockup input shafts and stator supports share the same spline counts and diameters so even the diesel and V-10 can be swapped, not sure you would want to though.
The diesel and V-10 use 12-3/4” converters - the stall speeds differ drastically between the two.
And while I have never tried - I think the 12-3/4” converter may not fit the regular bellhousing.
Re: A-518 (46RH) converter interchange [Re: A727Tflite] #2643494
04/10/19 02:38 AM
04/10/19 02:38 AM
That is why you can't swap a diesel or V10 converter. They don't fit the bell housing and even if you could get it in there it would still stick out about an inch. The flex plate bolt pattern is different as well.
Re: A-518 (46RH) converter interchange [Re: Guitar Jones] #2643545
04/10/19 09:07 AM
04/10/19 09:07 AM
A727Tflite Offline
A727Tflite  Offline
You can’t put a clutch on the front of a 727 either.
Oh wait, yes you can. It’s called a Clutchfilte.
My response was directed at the fact the OP mentioned the spline count.
The 47/48 cases became extinct a while back so we modified no less than 20 cases this way for an off road program.
One was also used in a blown Hemi application using that monster converter.
Re: A-518 (46RH) converter interchange [Re: A727Tflite] #2643548
04/10/19 09:12 AM
04/10/19 09:12 AM
And my response was directed at feets. While you can modify anything to fit just about anything, that isn't what is implied by "interchange". That would be a direct swap, not a machining and fabrication process. Thank you for the insight.
Re: A-518 (46RH) converter interchange [Re: Guitar Jones] #2643549
04/10/19 09:14 AM
04/10/19 09:14 AM
A727Tflite Offline
A727Tflite  Offline
And thank you for your’s.
I would really like to meet you some times. You sound like a pretty neat guy.
And I’ve never met a guy named Guitar before so that would be neat too.
Re: A-518 (46RH) converter interchange [Re: A727Tflite] #2643614
04/10/19 11:12 AM
04/10/19 11:12 AM
Well if you ever come down to Florida give me a shout. I'm sure not going up to Michigan though. laugh2
Re: A-518 (46RH) converter interchange [Re: Guitar Jones] #2643664
04/10/19 01:23 PM
04/10/19 01:23 PM
A727Tflite Offline
A727Tflite  Offline
Don’t blame you a bit about not coming up here.
You probably have heard we only have two season here - winter and construction zones.
Re: A-518 (46RH) converter interchange [Re: A727Tflite] #2643745
04/10/19 05:12 PM
04/10/19 05:12 PM
We have plenty of construction zones here as well but where you have 3 days of summer (July 3rd, 4th, and 5th) we have 3 days of winter, usually in January but the days vary year to year. laugh2
Re: A-518 (46RH) converter interchange [Re: Guitar Jones] #2643804
04/10/19 08:22 PM
04/10/19 08:22 PM
A727Tflite Offline
A727Tflite  Offline
How far from Gainesville are you?
Re: A-518 (46RH) converter interchange [Re: A727Tflite] #2643916
04/11/19 03:50 AM
04/11/19 03:50 AM
About 2.5 hours.
Re: A-518 (46RH) converter interchange [Re: Guitar Jones] #2644226
04/11/19 11:38 PM
04/11/19 11:38 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
The converters changed in 96 when the RE trans was phased in. The flex plate pattern is symmetrical as opposed to the RH which is the normal one way only.
Carl Kessel
Re: A-518 (46RH) converter interchange [Re: CKessel] #2644275
04/12/19 06:02 AM
04/12/19 06:02 AM
Good point, I had forgotten about that.
