Re: A-518 (46RH) converter interchange
[Re: A727Tflite]
#2643354
04/09/19 06:22 PM
04/09/19 06:22 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Does the same hold true for the lock up converters?
[Re: feets]
#2643364
04/09/19 06:37 PM
04/09/19 06:37 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
Does the same hold true for the lock up converters? Yes, lockup to lockup except for V10 and diesel converters.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2643429
04/09/19 09:19 PM
04/09/19 09:19 PM
Posts: 3,069 Michigan
A727Tflite
All large family lockup input shafts and stator supports share the same spline counts and diameters so even the diesel and V-10 can be swapped, not sure you would want to though.
The diesel and V-10 use 12-3/4” converters - the stall speeds differ drastically between the two.
And while I have never tried - I think the 12-3/4” converter may not fit the regular bellhousing.
[Re: A727Tflite]
#2643494
04/10/19 02:38 AM
04/10/19 02:38 AM
Guitar Jones
That is why you can't swap a diesel or V10 converter. They don't fit the bell housing and even if you could get it in there it would still stick out about an inch. The flex plate bolt pattern is different as well.
[Re: A727Tflite]
#2643548
04/10/19 09:12 AM
04/10/19 09:12 AM
Guitar Jones
And my response was directed at feets. While you can modify anything to fit just about anything, that isn't what is implied by "interchange". That would be a direct swap, not a machining and fabrication process. Thank you for the insight.
[Re: Guitar Jones]
#2643549
04/10/19 09:14 AM
04/10/19 09:14 AM
A727Tflite
And thank you for your’s.
I would really like to meet you some times. You sound like a pretty neat guy.
And I’ve never met a guy named Guitar before so that would be neat too.
[Re: A727Tflite]
#2643614
04/10/19 11:12 AM
04/10/19 11:12 AM
Guitar Jones
Well if you ever come down to Florida give me a shout. I'm sure not going up to Michigan though.
[Re: A727Tflite]
#2643745
04/10/19 05:12 PM
04/10/19 05:12 PM
Guitar Jones
We have plenty of construction zones here as well but where you have 3 days of summer (July 3rd, 4th, and 5th) we have 3 days of winter, usually in January but the days vary year to year.
[Re: A727Tflite]
#2643916
04/11/19 03:50 AM
04/11/19 03:50 AM
Guitar Jones
[Re: Guitar Jones]
#2644226
04/11/19 11:38 PM
04/11/19 11:38 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
The converters changed in 96 when the RE trans was phased in. The flex plate pattern is symmetrical as opposed to the RH which is the normal one way only.
Carl Kessel
[Re: CKessel]
#2644275
04/12/19 06:02 AM
04/12/19 06:02 AM
Guitar Jones
Good point, I had forgotten about that.
