Street stroker quench ?? #2642870
04/08/19 05:33 PM
04/08/19 05:33 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I have a 528" stroker for street use. Between decking the block to get the decks straight and line honing the pistons are now out of the hole .016". The 528" pistons have a very short skirt so piston rock also plays a part here. With the thickest Felpro head gasket (.052") I'm left with .036" quench. I think this is too close for comfort for a street motor. Using Cometic MLS gaskets isn't an option because the block (and probably the heads as well) don't have the correct RA finish. I contacted Cometic and they can make a standard style custom thickness gasket. Looking for some thoughts here. What's a "safe" quench dimension for a street motor?
Re: Street stroker quench ?? [Re: Stanton] #2642896
04/08/19 06:42 PM
04/08/19 06:42 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have and do currently run .030 on a SB without blinking an eye, I don't think you have anything to worry about as far as piston to head.
Re: Street stroker quench ?? [Re: Stanton] #2642900
04/08/19 06:51 PM
04/08/19 06:51 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Racers have successfully used Cometic gaskets with RA all over the map and copper coat
For quite some time now. I realize it's not perfect and it's not recommended by the manufacturer, but sometimes
You have to make do....
Rich H.
Esse Quam Videri
Re: Street stroker quench ?? [Re: Stanton] #2642909
04/08/19 07:10 PM
04/08/19 07:10 PM
AndyF Offline
AndyF  Offline
You could probably shave a little off the tops of the pistons.
Re: Street stroker quench ?? [Re: AndyF] #2642920
04/08/19 07:40 PM
04/08/19 07:40 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
On my 512 low deck, I used the .051 Cometic with piston .016 out of the hole.
Re: Street stroker quench ?? [Re: CSK] #2643013
04/08/19 10:40 PM
04/08/19 10:40 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
The motor is fully assembled. Thicker custom head gaskets are the easy answer - if deemed necessary.
Re: Street stroker quench ?? [Re: Stanton] #2643018
04/08/19 10:47 PM
04/08/19 10:47 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
just ring Cometic and order the thickness you need .
I have 0.040gasket for 0.040-0.042 quench in my 505 , I think i ran 0.037-.0.038 quench on my old 505
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Street stroker quench ?? [Re: Stanton] #2643026
04/08/19 11:10 PM
04/08/19 11:10 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
0.036" on a street engine should be fine. What is the peak RPM the engine see, 6,000 RPM?
Re: Street stroker quench ?? [Re: Stanton] #2643057
04/09/19 12:41 AM
04/09/19 12:41 AM
AndyF Offline
AndyF  Offline
Originally Posted by Stanton
Quote
Does the person who put the motor together with the pistons sticking out have any ideas on how to solve the problem?
Re: Street stroker quench ?? [Re: AndyF] #2643062
04/09/19 01:24 AM
04/09/19 01:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
.036 should be fine.. dont worry about the RA just use copper coat in it
wave
Re: Street stroker quench ?? [Re: Stanton] #2643073
04/09/19 03:17 AM
04/09/19 03:17 AM
Cab_Burge Online work
Cab_Burge  Online Work
Go through and check all eight pistons at TDC and use a thin bladed screw driver between the tops of the pistons on the cam side and motor mount side to rock the pistons as far over as you can get them both ways and measure the piston height above the decks on the outer edges and go from there scope
If you get .020 or less above the decks I would run it up If it is above .022 or more get a thicker head gasket up twocents
Re: Street stroker quench ?? [Re: Cab_Burge] #2643074
04/09/19 03:23 AM
04/09/19 03:23 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Whose piston and whose rod? .035 is ok for a street engine but barely. RPMs will also come into play there. Hate to mention it now but you might want to check the Piston to valve with the pistons rocking around like you noted.
Todd
Re: Street stroker quench ?? [Re: sasquatch] #2643136
04/09/19 09:48 AM
04/09/19 09:48 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Quote
No he doesn't. It pisses me off that he didn't measure the deck heights and do some basic math before machining things. At some point he could have said it was going to be tight and I would have found another block.
Re: Street stroker quench ?? [Re: Stanton] #2643149
04/09/19 10:14 AM
04/09/19 10:14 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Been there, done that. Plenty of ways to skin a cat...one of them being (what I would do FWIW) first measure p-2-v. Provided there is adequate clearance remove pistons and chuck them up in a lathe with a thin aluminum band around the ring pack area (round grab) and cut .005" or so off the top, reassemble.
Re: Street stroker quench ?? [Re: Stanton] #2643151
04/09/19 10:15 AM
04/09/19 10:15 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
How close is the top ring to the deck? Is there a bevel at the top of the bore?
Re: Street stroker quench ?? [Re: bobby66] #2643188
04/09/19 11:39 AM
04/09/19 11:39 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
The difference between where the piston is supposed to sit at TDC (-.009) and where it is (+.016) is not enough to matter about the ring or bevel.
Re: Street stroker quench ?? [Re: Stanton] #2643221
04/09/19 12:58 PM
04/09/19 12:58 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Big bore, short piston........ I’d be shooting for around .050 piston to head clearance.
Re: Street stroker quench ?? [Re: Stanton] #2643370
04/09/19 06:57 PM
04/09/19 06:57 PM
AndyF Offline
AndyF  Offline
Quote
Yeah that is a bummer. Typically I'd get a call from the engine builder saying "um, your block is a little short. What should we do". I'd be pissed if I showed up and the pistons were sticking out of the holes since now you have limited options.
Re: Street stroker quench ?? [Re: 451Mopar] #2643392
04/09/19 07:42 PM
04/09/19 07:42 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think even with piston rock you will have 0.030" min clearance. That should be OK with steel rods and 6,000 RPM.
I know 0.020" is too tight on a 440, but the engine ran for quite some time until it was over-reved.
Re: Street stroker quench ?? [Re: 451Mopar] #2643420
04/09/19 08:53 PM
04/09/19 08:53 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
KInd of had the same scenario with the R1 block in my car. When we put it together the pistons were out of the hole, machine shop forgot to say that the block needed a little more taken off to square it up. We were able to fix the issue with .056 cometic gaskets. I will say the cometic have worked great and I will re use them after this top end refresh.
68 Barracuda Formula S 340
