Think I fried a fresh 727 on break in
#2634132
03/18/19 06:03 PM
03/18/19 06:03 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
I had never rebuilt a transmission before but I bought a book and there wasn’t that much stuff in there- it all reminded me of a harley shovelhead and evo clutch packs. I just got done breaking in a fresh motor after a timy bit of valvetrain carnage and after tuning the idle I tried putting it in gear. Well I’ve idled and revved in every gear, let it sit in N while I checked and added fluid, made sure the axles were free to spin in N (truck is on jackstands for break in), there just is no jolt into any gear and the jacked up rear tires haven’t even threatened to spin in either direction. Now I’m doing some reading online and I must have skipped the last chapter of that 727 book because I didn’t know to put it in N or gear so the pump can run to fill the converter and keep everything happy. “Why slam the gears at 2700 rpm” I thought. I never had a hotrod with an auto trans, I’ve just put used ones in and swapped converters before. Everything had a nice swab of grease on it but the converter was dry. Funny because I know better- I always threw a quart in there before installing one. I just didn’t feel like making a mess and figured it’d fill up after a minute of running. I have a deep pan and pickup and a tf2 kit installed on the trans, a cheap just above entry level 2500 stall B&M converter, and the cable shifter & lokar throttle pressure (kickdown) were properly installed. The pan had six or seven quarts in it and I put one more in after tuning my idle. It looks like I’m going to be pulling the trans or maybe the whole driveline. What should I expect to find in there? I couldn’t have smoked the clutches because apparently there was never any line pressure The fluid on the dipstick still looks new. Maybe the converter, pump, and any seals that could be smoked from not getting oil? Any good parts sources? Or am I jumping the gun and these symptoms could be from a mistake assembling the valve body? Good thing I got a sense of humor! And it’s also good this is a toy I enjoy working on not my daily or business truck. I just wish I wasn’t learning so many lessons the hard way!
Re: Think I fried a fresh 727 on break in
[Re: radar]
#2634140
03/18/19 06:20 PM
03/18/19 06:20 PM
Posts: 11,542 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If it was all fresh and new, it's gonna take more than 6 or 7 quarts with a deep pan.
[Re: radar]
#2634157
03/18/19 07:18 PM
03/18/19 07:18 PM
Posts: 4,848 Memphis
HemiRick
Memphis
How much fluid have you put in it? Still sounds to me like not enough.....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2634165
03/18/19 07:37 PM
03/18/19 07:37 PM
radar
Philadelphia
Around 7 quarts I think? but if the pump isn’t circulating the fluid it would still read full right? Because the torque converter, cooler, etc would all stil be empty?
I only know how to put a funnel into the dipstick tube I don’t know how to prime anything or make the pump create pressure if it isn’t...
[Re: radar]
#2634198
03/18/19 08:43 PM
03/18/19 08:43 PM
Posts: 4,206 New York
polyspheric
New York
Unlss the ATF level was below the pick-up the converter will fill by itself, but (of course) that will lower the level.
Boffin Emeritus
[Re: radar]
#2634202
03/18/19 08:52 PM
03/18/19 08:52 PM
radar
Philadelphia
Ok so I’m going back through my Tom Hand book and looking at TF2 specs and it says the TF2 fills the converter in park.
Maybe I just need to go through the gears slowly a bunch and add more fluid?
What about the cooler line not getting pressure? Am I fubar’d?
Thanks fellas I really appreciate the experienced advice- Like I said I never built a 727 before!
I did make sure the converter was fully seated before I mated the trans to the flexplate & motor.
[Re: radar]
#2634204
03/18/19 08:57 PM
03/18/19 08:57 PM
Posts: 1,111 Usa
A39Coronet
Usa
[Re: A39Coronet]
#2634217
03/18/19 09:43 PM
03/18/19 09:43 PM
radar
Philadelphia
Forward drum piston in backwards I my guess...all fluid bypasses piston seal and clutches won't apply, no fluid anywhere else. Ask me how I know, cost me the sale of my car this winter unfortunately after a fresh rebuild. Oof sorry to hear that! Do you mean the one under the lever forward of the accumulator? I didn’t take a ton of pix while rebuilding my 727 but here’s one where you can see the piston installed- does it look ok?
[Re: radar]
#2634233
03/18/19 10:18 PM
03/18/19 10:18 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If it's not moving oil through the cooler, either there's not enough oil in it or something is not together right in the front of the trans. I don't know what kind of dipstick you have, but have you checked the length of the thing? If it's long for the tube, it won't read right. If you only have 7 quarts in it, I would put another quart or two in it and see what happens, regardless what the stick says,
[Re: Twin Turbo Mower]
#2634252
03/18/19 11:37 PM
03/18/19 11:37 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
If it is a stock oil pump the tangs/tabs on the pump gear might have broken off when installing the converter. And was the converter seated into the pump?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#2634260
03/19/19 12:12 AM
03/19/19 12:12 AM
radar
Philadelphia
If it is a stock oil pump the tangs/tabs on the pump gear might have broken off when installing the converter. And was the converter seated into the pump? Yes I think so. I remember the night I married the trans to the motor it took forever to drop all the way in and I didn’t force anything when it bolted to the block and flexplate Thinking back it’s likely I took that pic before seeing my mistake and changing that kickdown situation so it didn’t stick up all crazy. I remember having to do that part twice
[Re: radar]
#2634274
03/19/19 02:58 AM
03/19/19 02:58 AM
Posts: 3,069 Michigan
A727Tflite
The book is wrong and somehow I made a typo. My earlier post should say “ ,not park”.
You have to be in neutral to get any substantial flow out of the cooler line.
You will be there forever trying to fill the converter in park.
Run the engine with the trans in neutral while filling the trans. Sounds like you are low at this point.
