Re: VVT cam swap question
[Re: ric3xrt]
#2633024
03/15/19 01:26 PM
03/15/19 01:26 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Dont lock out the cam timing and ignore whatever your reading and stick the 6.4 cam in, I have done it and it works great.
[Re: HotRodDave]
#2633104
03/15/19 05:40 PM
03/15/19 05:40 PM
Posts: 112 Michigan
ghinmi
You are most likely seeing specs for an early 2008 and older 5.7 hemi. The 2009+ 5.7 uses the same style camshaft as a 6.4 does. The 6.1 cam will not fit any 5.7 2009 or newer.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
[Re: HotRodDave]
#2633223
03/16/19 05:32 AM
03/16/19 05:32 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Dont lock out the cam timing and ignore whatever your reading and stick the 6.4 cam in, I have done it and it works great. Dave if he's using it in a Non VVT application he should lock it straight up, And like Dave has said the 6.4SRT cam in the 5.7 , is great starting place. and you can't beat the price.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ghinmi]
#2633224
03/16/19 06:00 AM
03/16/19 06:00 AM
Posts: 776 Eastern WA
ProStock1320
Eastern WA
I am so thankful for this forum - answers straight from those with the experience.
ric - greatly appreciate the thread. I tried to use the search feature but I obviously failed miserably.
Dave - I'll follow your advice. I'm sure this won't be the last issue I run into.
ghinmi - One of the publications I'm using is New Hemi Engines: How To Build Max Performance by Larry Shepard (SA 404). My confusion was from the Common Camshaft Journal Specs chart on page 62. Your explanation makes perfect sense when the year break (early vs VVT cams) is considered - but that's not what the chart says. I will send the author a note to address the confusion.
Again, thank you to everyone for your assistance and willingness to share your knowledge.
