VVT cam swap question #2632886
03/15/19 07:17 AM
03/15/19 07:17 AM
Eastern WA
P
ProStock1320 Offline OP
P
Eastern WA
This is my first foray into G3 engines so please forgive my ignorance. I have a 5.7 from a 2011 Ram 1500 with +/- 130K miles. I'm going to lockout the VVT & delete the MDS solenoids. In rebuilding this, I'm considering a cam swap but the Number 1 cam bearing journal diameter is 2.29 on the 5.7 and listed as 2.67 for the 6.4.
So, can the Number 1 bearing journal be machined for the larger 6.4 cam bearing or do I get the 6.4 cam and turn down the snout to 5.7 journal dimension?
I'd look at the 6.1 cam but do not know if the 6.1 ever ran VVT so the length of the cam would be an issue, wouldn't it?
Not interested in a $600 cam.
Thanks for any insight.
Re: VVT cam swap question [Re: ProStock1320] #2632893
03/15/19 07:57 AM
03/15/19 07:57 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
"Number 1 cam bearing journal diameter is 2.29 on the 5.7 "
that makes no sense, the 5.7 VVT is the same size as the 6.2/6.4 ,the older (pre VVT) 5.7 and all 6.1 blocks are 2.29
Here's a goods thread to read thru
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2413476/1.html
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: VVT cam swap question [Re: ric3xrt] #2633024
03/15/19 01:26 PM
03/15/19 01:26 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Dont lock out the cam timing and ignore whatever your reading and stick the 6.4 cam in, I have done it and it works great.
Re: VVT cam swap question [Re: HotRodDave] #2633104
03/15/19 05:40 PM
03/15/19 05:40 PM
ghinmi Offline
ghinmi  Offline
You are most likely seeing specs for an early 2008 and older 5.7 hemi. The 2009+ 5.7 uses the same style camshaft as a 6.4 does. The 6.1 cam will not fit any 5.7 2009 or newer.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: VVT cam swap question [Re: HotRodDave] #2633223
03/16/19 05:32 AM
03/16/19 05:32 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Dave if he's using it in a Non VVT application he should lock it straight up,
And like Dave has said the 6.4SRT cam in the 5.7 , is great starting place. and you can't beat the price.
Re: VVT cam swap question [Re: ghinmi] #2633224
03/16/19 06:00 AM
03/16/19 06:00 AM
Eastern WA
P
P
Eastern WA
I am so thankful for this forum - answers straight from those with the experience.
ric - greatly appreciate the thread. I tried to use the search feature but I obviously failed miserably.
Dave - I'll follow your advice. I'm sure this won't be the last issue I run into.
ghinmi - One of the publications I'm using is New Hemi Engines: How To Build Max Performance by Larry Shepard (SA 404). My confusion was from the Common Camshaft Journal Specs chart on page 62. Your explanation makes perfect sense when the year break (early vs VVT cams) is considered - but that's not what the chart says. I will send the author a note to address the confusion.
Again, thank you to everyone for your assistance and willingness to share your knowledge.
