Re: Ate a couple lifters- never seen that before
[Re: radar]
#2632355
03/13/19 05:00 PM
03/13/19 05:00 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
Guess I better make sure those pushrods are not bent too...
Edit: yup the one that did all the smashing #7 exhaust has a wobble you can hear but not really see when rolling it on glass. Time for some pushrods too.
After having a moment to reflect I guess the shaft got loose enough to let the pushrod out of the pocket in the rocker, then did a little smashing while misaligned in the lifter, then the shaft finished loosening up until it wasn’t even opening the valve any more.
[Re: radar]
#2632361
03/13/19 05:14 PM
03/13/19 05:14 PM
Posts: 150 It's Complicated
HDNMOPERS
It's Complicated
I got a brand new set of 16. Hy-Lift Johnson slow bleed HYD Lifters. If your interested in them.
[Re: sasquatch]
#2632461
03/13/19 10:24 PM
03/13/19 10:24 PM
RapidRobert
As you surmised I'd say the rocker bolts coming loose caused all the carnage. As you are doing replace the lifters (make sure they ain't too tight in the lifter bore(s)/check/replace the pushrods & #1 find out/address how the rocker bolts were/came loose. As you go together you might check/note preload.
[Re: radar]
#2632514
03/14/19 02:34 AM
03/14/19 02:34 AM
Posts: 43,126 Bend,OR USA
Cab_Burge
I would make sure the rocker arm shaft bolts are at least grade 5 or better and make sure to NOT over torque them The FSM calls for 23 to 25 Ft. Lbs. and that is what I use.(although I convert those numbers to inch Lbs. and use my 3/8 drive 100 to 750 inch lb. torque wrench on any torque below 30 Ft. Lbs. 23x12=276 inch Lbs., 12x25=300 inch lbs., correct ) I do check them at least three times while assembling the motor and again after warming up the motor to break the cam and lifters in and recheck the valve lash and inspect for F.O.D. in the heads in case of something going horribly wrong like you had Good luck on your deal
[Re: radar]
#2632572
03/14/19 10:15 AM
03/14/19 10:15 AM
radar
Philadelphia
Ok so I went out got a really good cleaning and look at the threads on my bolt and head. Somehow the rocker stand threads still look sharp and the bolt threads down nicely. Hard to believe the last two bolts would just work loose like that with almost constant pressure on them as the rockers work the valves. Break in rpm is definitely loud though so I can see how I wouldn’t have noticed it until it realls clattered? Still I’m surprised. While I was trying to drift off to sleep last night I kept thinking how could the pushrod have slipped far enough out of the dimple in the rocker and simultaneously wedged either to coil bind or too far toward the fulcrum of the rocker to have good leverage? The pushrods don’t contact their holes through the head but don’t have a ton of room to misalign- the holes aim at the lifters pretty well. Or did the pushrod just slip over into the lifter’s snapring/retention wire area then the cocked piston in the lifter bore broke the little sheetmetal piece underneath before it spat out the piston? And how did the intake lifter piston get cocked in its lifter bore? And if enough force was transmitted from the rocker, which was anchored by bolts that were unscrewing fast enough to cause problems in less than 5 minutes of 2500-2700 rpm, how did it not pull the remaining threads holding the shaft bolts right out of the aluminum rocker stand?! What a freaky thing. I actually have a video of it from my wife’s phone I posted on yootoob- you can hear a hint of a problem starting in the middle of the video but it was tough to hear in the heat of the moment at rpm before it was too late. Skip to 2:45 through to hear the carnage happen. I think after that it was still running on 7 cyls pretty well with the one cylinder only slightly opening the intake and the exhaust valve staying closed! The rpm didn’t change a ton and there were no additional horrible noises. On the other hand a healthy 448” V7 motor should make enough power to drag a dead hole along for the ride. https://youtu.be/pyZlQqcrNkI
[Re: radar]
#2632700
03/14/19 04:16 PM
03/14/19 04:16 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
If it were mine, I would be checking the rocker shafts as well to make sure they are not bent.
I agree you dodged a bullet, it could have been much, much worse.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2632704
03/14/19 04:27 PM
03/14/19 04:27 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The shaft bolts get loose, then you have some clearance between the pushrods and the rockers/lifters, pushrods are jumping around in the lifters & rockers, hammering all the pieces involved....... and you’re gonna end up with a few broken pieces.
Stuff happens........ you caught it before it got real ugly.
[Re: Porter67]
#2632802
03/14/19 08:54 PM
03/14/19 08:54 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Does the Stealth head use heli coils for the rocker arm shaft threaded bosses ?
Never installed a Stealth head
Was nice to see that the Edelbrock E Street used heli coils and supplied studs for 2 and 4 bosses
However
Was not nice to see the some what broken off heli coil tangs left in the bottom of the holes in three spots when I was trying to torque everything down
Avoided a messy situation there
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Porter67]
#2632856
03/14/19 11:54 PM
03/14/19 11:54 PM
radar
Philadelphia
To me it sounds like at approx 36 seconds in on your vid it dont sound well. Sounds like its already laboring imo.
Hope its a easy fix. I had my thumb on the throttle and couldn’t understand why my buddy wouldn’t spin the curb idle screw until I could let it go. Turns out he was trying to be smart and run back and forth to look at the tach but that dip in rpm was me checking to see if I could let the throttle go yet or not and yelling at him to zing up that curb idle asap. My floats were way high and it was running super duper rich. I’m still not sure if I did it again if I would have heard it starting to let go and know to open the valvecovers. I’ve had adjustable lifters on solids open up before but always heard a tap and shut her down. Guess it was my torqueing negligence mixed with a freak thing. The stealths have room to run 1/4” longer bolts without flirting with the bottoms of the blind holes. I’m gonna spray out the holes with brakleen and shop air a few times then blue loctite them in next time. I got new pushrods, just waiting on lifters and gonna order some new grade 5 or 8 bolts off mcmaster.
[Re: radar]
#2632862
03/15/19 12:56 AM
03/15/19 12:56 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I do NOT recommend loctite on the bolts
[Re: CSK]
#2632866
03/15/19 01:19 AM
03/15/19 01:19 AM
RapidRobert
X2 no loctite & my Super Stealths have inserts so I would highly assume the Stealths do also. Not sure about grade 8 but I will defer to others on this. EDIT yes spray em out with brake kleen & eyeball em to see if the threads look good then run a bolt in there & see if it threads in/out good then we will see about advise on a lube. I usually dip threads in 30 oil then blow em off with shop air. On a side note I would pick a cyl that is on TDC compression & see what the preload is (not that I think it caused this) but it is important.
[Re: 540DUSTER]
#2633002
03/15/19 12:41 PM
03/15/19 12:41 PM
radar
Philadelphia
did you fill the lifters with oil before you started engine? Do you have adjustable rockers? I soaked the lifters overnight but I didn’t take them apart and fill them or anything crazy. I also let the drill run for a minute when I primed the oil pump- dunno if it was clocked right to feed the lifter galleries but it didn’t noticably clatter on fireup. I’m running a comp .507” hft cam with extreme energy lifters and I bought comp 5/16” pushrods that are nice fartory low deck replacement deals- 8.555” iirc. The rockers and shaft are stock late 70s truck pieces out of the 400 donor motor I stroked.
[Re: CSK]
#2633134
03/15/19 07:28 PM
03/15/19 07:28 PM
radar
Philadelphia
I do NOT recommend loctite on the bolts I could see a bunch of loctite crumbs causing problems in the oil pump maybe but why not clean the threads and bolts nice and dry and smear a drop of blue loctite on the first few threads? Also I’ve used adjustable pushrods to preload hydraulic lifters on harleys a million times and set lash on tons of solid flat tappets in v8s but all I ever did on a non adjustable setup was make sure the pushrods had no lash but still could be spun in my fingers on the heel of the cam. I guess with the valley open I can spin it around a little and look at the lifter bodies and make sure the lifter pistons are uniformly depressed an appropriate amount from a fully extended lifter? The motor didn’t really have any lifter clatter or anything before the poo hit the fan. I just want to put it back together and feel confident- I’m not really sure why this happened unless I just didn’t properly torque the rear bolt in the first place.
[Re: radar]
#2633143
03/15/19 08:21 PM
03/15/19 08:21 PM
CSK
Pattison Texas
I do NOT recommend loctite on the bolts I could see a bunch of loctite crumbs causing problems in the oil pump maybe but why not clean the threads and bolts nice and dry and smear a drop of blue loctite on the first few threads? Also I’ve used adjustable pushrods to preload hydraulic lifters on harleys a million times and set lash on tons of solid flat tappets in v8s but all I ever did on a non adjustable setup was make sure the pushrods had no lash but still could be spun in my fingers on the heel of the cam. I guess with the valley open I can spin it around a little and look at the lifter bodies and make sure the lifter pistons are uniformly depressed an appropriate amount from a fully extended lifter? The motor didn’t really have any lifter clatter or anything before the poo hit the fan. I just want to put it back together and feel confident- I’m not really sure why this happened unless I just didn’t properly torque the rear bolt in the first place. For one, the 2nd bolt from the rear has an oil passage for the rockers, 2. if you remove the bolts after you have put on loctite the Heli Coil will likely get uscreewed out of the aluminum cyl head, not what you want, 3. why do it, there is no reason to, not done from mamopar, or ANYone that I know of, none on my stealth heads, yours came loose because they where never tighten down correct.
[Re: radar]
#2633264
03/16/19 10:35 AM
03/16/19 10:35 AM
RapidRobert
I just want to put it back together and feel confident- I’m not really sure why this happened unless I just didn’t properly torque the rear bolt in the first place. that'd be my guess (it happens to all of us at one time or another). To do lifters to the nth degree (which I do now after my recent lifter fiascoes!) is take em apart & clean thoroughly then reassemble dry then install em & set preload individually if I have adjustable rockers & if not then I before hand on mockup individually checked preload (it should be about the same on all of em but cant assume anything for everything being the same length/dimention) then get #1 cyl to 15 BTDC compression then preoil. I also toss the flimsy clips & use hardware store 11/16 internal snap rings in their place & a guy said to have the sharp edge side down which I thought was backwards but I am going with what he said. It might be better to lightly lube internals with WD40 as opposed to dry & I am open to changeing that but that is where I am at now. Holler how it turns out
[Re: radar]
#2633326
03/16/19 12:28 PM
03/16/19 12:28 PM
CSK
Pattison Texas
And thanks for all the help and for not beatin me up too bad for soft torquing that bolt😘 Heck my life of working on cars is FULL of mistakes & I know there will be many more for me LOL, Keep us posted !!!
[Re: CSK]
#2633328
03/16/19 12:31 PM
03/16/19 12:31 PM
Cab_Burge
[quote=radar
Heck my life of working on cars is FULL of mistakes & I know there will be many more for me LOL, Keep us posted !!! The only way I learn to remember to NOT REPEAT mistakes is to have to learn how to fix them
[Re: radar]
#2633350
03/16/19 01:16 PM
03/16/19 01:16 PM
RapidRobert
Also I don’t see a helicoil in the rocker stands on my stock stealths- maybe the ported model has them? I wonder if it was an assembly line slip up on their end, I would think if alum stands needed em that it would be the same across the board on all of em.
[Re: RapidRobert]
#2633429
03/16/19 06:11 PM
03/16/19 06:11 PM
CSK
Pattison Texas
Also I don’t see a helicoil in the rocker stands on my stock stealths- maybe the ported model has them? I wonder if it was an assembly line slip up on their end, I would think if alum stands needed em that it would be the same across the board on all of em. the 1,3,5 holes have the heilicoil, 2&4 do not
[Re: CSK]
#2633436
03/16/19 06:50 PM
03/16/19 06:50 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
These are aluminum heads?
Either way, grade 8 bolts are wrong for the application. You can't stretch the bolt properly without risking damage to the threads in the head. If the heads are cast iron, then I would feel comfortable with grade 5 uncoated bolts. Coated bolts change the torque requirement.
If the heads are aluminum, then I am a strong proponent of studs. Because you don't have the high friction on the internal threads while torquing with studs, the studs torque better, and you have a lesser chance of damaging the threads. Remember that when torquing a bolt the bolt is twisting during the torquing process - studs don't have that problem. Also remember that if you over-torque the bolts you can yield the bolt or internal threads or both and then not have proper clamping force. Once yielded its not possible to have proper clamping.
Most pf the time you can get away without proper clamping/bolting practices, but eventually it can bite you when you have a more difficult clamping application. I consider rocker clamping more difficult than most bolting on an engine. In my work life, I have been involved in quite a few bolting failures, and some were super expensive. Because I'm anal, I try to follow clamping/bolting best practices on everything I put together.
[Re: markz528]
#2633452
03/16/19 08:11 PM
03/16/19 08:11 PM
radar
Philadelphia
I get that for sure but I always felt like I’d oval the shaft before any stretching happened? I thought the rocker shaft roundness was the weak link in this operation, at least with stock hold down spacer/washers which don’t apply force to a whole 180 degrees like a fancy billet hold down.
[Re: radar]
#2633455
03/16/19 08:37 PM
03/16/19 08:37 PM
Cab_Burge
I get that for sure but I always felt like I’d oval the shaft before any stretching happened? I thought the rocker shaft roundness was the weak link in this operation, at least with stock hold down spacer/washers which don’t apply force to a whole 180 degrees like a fancy billet hold down. You are correct on the stock shafts and their weaknesses I've had to file more than one shaft ends to get adjustable rocker arms off of them when someone else had over tighten them
[Re: Cab_Burge]
#2633767
03/17/19 05:04 PM
03/17/19 05:04 PM
radar
Philadelphia
Ok so this morning I reassembled the valvetrain and top end and gave her another shot at the break in period. Here’s a video. A couple minutes after this it started getting real hot so I shut her down, waited a bit, and added more antifreeze. Hopefully it just needed more burping. I started it back up after waiting for it to cool some more and I saw the temp climb then come back down as the thermostat opened, then start slowly climbing again. It got to around 210 before I shut it down again. The RPMs were starting to hunt a little bit which was worrying. The AFR was reading around 9-10 which is PIG rich- I dunno if it even matters with no load on the motor? I did fix the floats so they’re not high any more. Dunno if twiddling the 4 idle screws would even make a difference with the throttle open to het 2500-3000 rpm. Of course on shutdown I was treated to a little dieseling and a couple nice loud tailpipe backfires. I’m gonna call that normal for the throttle being open that far. The rpm hunting does have me worried though. I’m going to re-check the rockers before continuing the break in. I did get to hear the idle for as long as it took me to jump out after it started and zing up the curb idle screw- if I ever get this monster running right it is gonna sound nasty! https://youtu.be/ihPa2vJz7Ag
[Re: radar]
#2633817
03/17/19 08:12 PM
03/17/19 08:12 PM
RapidRobert
what do the plugs look like now?
[Re: radar]
#2633847
03/17/19 09:18 PM
03/17/19 09:18 PM
CSK
Pattison Texas
Ok so this morning I reassembled the valvetrain and top end and gave her another shot at the break in period. Here’s a video. A couple minutes after this it started getting real hot so I shut her down, waited a bit, and added more antifreeze. Hopefully it just needed more burping. I started it back up after waiting for it to cool some more and I saw the temp climb then come back down as the thermostat opened, then start slowly climbing again. It got to around 210 before I shut it down again. The RPMs were starting to hunt a little bit which was worrying. The AFR was reading around 9-10 which is PIG rich- I dunno if it even matters with no load on the motor? I did fix the floats so they’re not high any more. Dunno if twiddling the 4 idle screws would even make a difference with the throttle open to het 2500-3000 rpm. Of course on shutdown I was treated to a little dieseling and a couple nice loud tailpipe backfires. I’m gonna call that normal for the throttle being open that far. The rpm hunting does have me worried though. I’m going to re-check the rockers before continuing the break in. I did get to hear the idle for as long as it took me to jump out after it started and zing up the curb idle screw- if I ever get this monster running right it is gonna sound nasty! https://youtu.be/ihPa2vJz7Ag How is the dist timing set up, initial & total, vac adv hooked up ?
[Re: radar]
#2633849
03/17/19 09:25 PM
03/17/19 09:25 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
Ok so this morning I reassembled the valvetrain and top end and gave her another shot at the break in period. Here’s a video. A couple minutes after this it started getting real hot so I shut her down, waited a bit, and added more antifreeze. Hopefully it just needed more burping. I started it back up after waiting for it to cool some more and I saw the temp climb then come back down as the thermostat opened, then start slowly climbing again. It got to around 210 before I shut it down again. The RPMs were starting to hunt a little bit which was worrying. The AFR was reading around 9-10 which is PIG rich- I dunno if it even matters with no load on the motor? I did fix the floats so they’re not high any more. Dunno if twiddling the 4 idle screws would even make a difference with the throttle open to het 2500-3000 rpm. Of course on shutdown I was treated to a little dieseling and a couple nice loud tailpipe backfires. I’m gonna call that normal for the throttle being open that far. The rpm hunting does have me worried though. I’m going to re-check the rockers before continuing the break in. I did get to hear the idle for as long as it took me to jump out after it started and zing up the curb idle screw- if I ever get this monster running right it is gonna sound nasty! https://youtu.be/ihPa2vJz7Ag Did you run the motor enough before the lifter failure to know if this problem is new since then, or could these issues have been there before too? RPM hunting can be a vacuum leak
[Re: BSB67]
#2633854
03/17/19 09:42 PM
03/17/19 09:42 PM
RapidRobert
^^^ that is what I was getting at, that the 9-10:1 rich reading could be a gauge "reversal" from actually way too lean. Not my area, just thinking out loud
[Re: RapidRobert]
#2633879
03/17/19 11:06 PM
03/17/19 11:06 PM
radar
Philadelphia
Hi fellas!
I posted another thread with a clip of the idle sound. My valvetrain is sorted out for now. Break in almost done (5 mins left but had to fix a water leak)
I never worried about unloaded free rev afrs but I did go ahead and screw in the four corner idle screws to see if they still had any noticable effect at break in rpm. I started out with a B guitar string in the ifrs and the corner screws out 1.5 turns. I’ve found that restricting the IFR until best idle was achieved around 1.5 turns out has tended to give me a good balanced leanish cruise at light throttle with bigger motors. I don’t usually do much with the air bleeds unless the curve needs tweaking.
Anyway, it did respond to the corner screws and seemed much happier and didn’t hunt rpms anymore. It was reading 9s and now it’s up in the high 10s/low 11s on the meter. That’ll do the trick for break in. Once I get it to idle for more than 10 seconds I’ll really find out where the corner screws end up, then decide if I go looking for thicker guitar strings to restrict the IFRs. If I wasn’t so lazy I’d tap them and make little jets or just buy billet ones...
[Re: radar]
#2633904
03/18/19 03:02 AM
03/18/19 03:02 AM
Cab_Burge
By adding the IFR (if your installing them into the air bleeds and not the idle fuel feed channels)you are enrichening the mixture, remove them and shoot for 14.5+ AFR at high idle above 1500 RPM, use the secondary throttle blades also to get the RPM you want, not just the primary throttle blades I drill and tap both the idle fuel feed channels and the power valve fuel feed channels to #6x32 and use blank allen headed brass set screws that I drill out to the size I want to fine tune the AFR at idle and at slight power valve opening and then tune the high speed air bleeds sizes for the WOT AFR tuning What year is your Dodge Pickup, 1954,55,56 or what year? I had a 1955 D500 flatbed that I converted into a car hauler and sold it to a friend and later buying a 1957 D300 whup car hauler that I ended up replacing the entire cab with fenders from a 1960 pickup, motor and a D60HD rear end out of Class B motor home chassis If your carb is a four corner idle carb try from 1/4 to 1 full turn out from bottom on all four mixture screws and see what that gets you on the AFR, if it is primary only idle mixture blocks try from 1 to 1 1/2 turns out from bottom with the secondary throttle blades barely opened at idle You really need to set the total timing as soon as possible, that can have a big effect on the idle quality and heating issues due to not enough advance, I shoot for 34 to 36 degrees total at or above when the mechanical advance is all in
[Re: radar]
#2634443
03/19/19 02:11 PM
03/19/19 02:11 PM
RapidRobert
Radar I'm glad that things are takeing a good turn for you cuz you certainly have had a run of bad luck here (eng & now trans).
