70 Barracuda Drag Project #2598340
12/29/18 01:03 PM
12/29/18 01:03 PM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
Hi Guys...newbee here...
I bought that 1970 Barracuda Dragcar that was on RacingJunk from Florida and brought it uphere too south of Bawstin...and hope to bring it too Epping this year.
It is an old build 383-727-513 Dana. I tore the engine and trany out and stripped the engine down to see what I got. It is a 383 30/over with stock rods shot-peened with TRW dome pistons and 906 heads that needs to be freshened up.
I want to go with aluminum heads and in pricing everything out I am only a few thousand from just getting a complete longblock 440 from vendors like Indy.
What do you guys think? Any recommendations on Mopar engine shops South of Bawstin area?
Thanx,Chip
Re: 70 Barracuda Drag Project [Re: Chip] #2598351
12/29/18 01:25 PM
12/29/18 01:25 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Cool,congrats. up
Not sure I understand ,,,,,,,a pair of heads to put on the 383 is about the same as a longblock 440 from Indy?
What are your power expectations?
need a little more of an explanation IMO. shruggy
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 70 Barracuda Drag Project [Re: Chip] #2598352
12/29/18 01:27 PM
12/29/18 01:27 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd put that motor back together and see what you can find in a complete used race motor. Don't know what it has for valve train and intake. But there is nothing in the long block you really want to upgrade with. Small cubes, stock rods, heavy pistons, factory heads.
Doug
Re: 70 Barracuda Drag Project [Re: Chip] #2598364
12/29/18 01:55 PM
12/29/18 01:55 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Another option to finding a complete used motor is buying a stroker rotating assy for the 383 block, and putting some nice heads on it.
.040 over is a 491, .060 over is a 496..... both using a 4.250 stroke.
Re: 70 Barracuda Drag Project [Re: 6bblFLASH] #2598371
12/29/18 02:08 PM
12/29/18 02:08 PM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
It's more than a pair of heads...
Gotta check the block and crank, new bearings, machine work
With new heads, need new cam, lifters, pushrods, rockerarm assembly, shop labor to assemble...
I still need to find a shop and discuss my options...but just good aluminum heads and accessories adds up to $4-$5K in parts
Re: 70 Barracuda Drag Project [Re: fast68plymouth] #2598376
12/29/18 02:13 PM
12/29/18 02:13 PM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
Good option, thanks. I see your running 906 heads?
Re: 70 Barracuda Drag Project [Re: 6bblFLASH] #2598379
12/29/18 02:15 PM
12/29/18 02:15 PM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
550-650 horsepower and mid 11 second results for now
Re: 70 Barracuda Drag Project [Re: dvw] #2598382
12/29/18 02:29 PM
12/29/18 02:29 PM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
Doug
I don't see much for used race engines out there
Re: 70 Barracuda Drag Project [Re: Chip] #2598383
12/29/18 02:38 PM
12/29/18 02:38 PM
N.Y.
sixpacksteve Offline
N.Y.
you should look a little harder!
Hell Hath No Fury Like Mine
Re: 70 Barracuda Drag Project [Re: Chip] #2598417
12/29/18 03:49 PM
12/29/18 03:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Have you looked in the race parts section??????
One just sold here for $3900. Another currently listed here in the race section for $7500. Along with these;
500 cube 400 base stroker shortblock,cleaned,magged,sonic tested,Arp main studs,align bored,square decked,bored and honed with torque plate,total seal file fit conventional piston rings,king rod and main bearings,molnar 4.150 crank,molnar h beam rods,Ross flat top pistons,balanced and assembled $3800
511 cube 400 base stroker same as above with GRP alum rods and 4.250 molnar crank
$4000
500 cube complete engine thumper carb to pan 13.5 to 1 BME alum rods $10900
500 cube street/strip 10.8 to 1 pump gas engine $9900 carb to pan
Doug
