Re: 70 Barracuda Drag Project
[Re: Chip]
#2598351
12/29/18 01:25 PM
12/29/18 01:25 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Cool,congrats. Not sure I understand ,,,,,,,a pair of heads to put on the 383 is about the same as a longblock 440 from Indy? What are your power expectations? need a little more of an explanation IMO.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: Chip]
#2598364
12/29/18 01:55 PM
12/29/18 01:55 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Another option to finding a complete used motor is buying a stroker rotating assy for the 383 block, and putting some nice heads on it.
.040 over is a 491, .060 over is a 496..... both using a 4.250 stroke.
[Re: fast68plymouth]
#2598376
12/29/18 02:13 PM
12/29/18 02:13 PM
Posts: 76 MASSACHUSETTS
Chip
MASSACHUSETTS
.040 over is a 491, .060 over is a 496..... both using a 4.250 stroke. Good option, thanks. I see your running 906 heads?
[Re: 6bblFLASH]
#2598379
12/29/18 02:15 PM
12/29/18 02:15 PM
Chip
MASSACHUSETTS
What are your power expectations? 550-650 horsepower and mid 11 second results for now
[Re: dvw]
#2598382
12/29/18 02:29 PM
12/29/18 02:29 PM
Chip
MASSACHUSETTS
I'd put that motor back together and see what you can find in a complete used race motor. Don't know what it has for valve train and intake. But there is nothing in the long block you really want to upgrade with. Small cubes, stock rods, heavy pistons, factory heads. Doug I don't see much for used race engines out there
[Re: Chip]
#2598383
12/29/18 02:38 PM
12/29/18 02:38 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
you should look a little harder!
Hell Hath No Fury Like Mine
[Re: Chip]
#2598417
12/29/18 03:49 PM
12/29/18 03:49 PM
Posts: 9,824 MI, usa
dvw
MI, usa
Have you looked in the race parts section?????? One just sold here for $3900. Another currently listed here in the race section for $7500. Along with these; 500 cube 400 base stroker shortblock,cleaned,magged,sonic tested,Arp main studs,align bored,square decked,bored and honed with torque plate,total seal file fit conventional piston rings,king rod and main bearings,molnar 4.150 crank,molnar h beam rods,Ross flat top pistons,balanced and assembled $3800
511 cube 400 base stroker same as above with GRP alum rods and 4.250 molnar crank $4000
500 cube complete engine thumper carb to pan 13.5 to 1 BME alum rods $10900
500 cube street/strip 10.8 to 1 pump gas engine $9900 carb to pan Doug
