Assassin bars and mini tub #2597385
12/27/18 12:54 AM
12/27/18 12:54 AM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
Anyone have the assassin bars and the leaf's moved in. Just wondering if there's any issues with the way they bolt on the leafs. As far as clearance in side the box where the front perch is in.
Re: Assassin bars and mini tub [Re: plycuda] #2597408
12/27/18 01:47 AM
12/27/18 01:47 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I don't think they are any different than caltrakz work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Assassin bars and mini tub [Re: hemi-itis] #2597422
12/27/18 02:26 AM
12/27/18 02:26 AM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
Caltrac make one just for a mini tub setup. Something on the part that goes over the leaf spring is welded instead of bolted.
Re: Assassin bars and mini tub [Re: plycuda] #2597790
12/27/18 10:50 PM
12/27/18 10:50 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The front mount is welded instead of a nut/bolt so it will fit in the confines of the front spring box when you move the springs inboard.
Re: Assassin bars and mini tub [Re: plycuda] #2597792
12/27/18 10:54 PM
12/27/18 10:54 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A quick look at the assassin setup and it looks to me like that front clamp with the u-bolts will be too wide to fit inside a spring box. You could always make your own wider ones.
Re: Assassin bars and mini tub [Re: plycuda] #2597820
12/28/18 12:07 AM
12/28/18 12:07 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My rear leafs are moved inboard 3" to the frame rails. No issues with the old Mopar Performance kit and using Caltracs w/split mono's.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Assassin bars and mini tub [Re: plycuda] #2597876
12/28/18 03:37 AM
12/28/18 03:37 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
My cousin took off Cal tracs and went with the Assassin bars and did not have to make any changers to the spring hanger
Old Geezer Racing
Re: Assassin bars and mini tub [Re: SCATPACK 1] #2597981
12/28/18 02:28 PM
12/28/18 02:28 PM
hemi-itis Offline
hemi-itis  Offline
Did you cousin pick up any??
I had to trim the boxes to fit the Cak Tracs....
Re: Assassin bars and mini tub [Re: plycuda] #2598005
12/28/18 03:29 PM
12/28/18 03:29 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
I have a home made relocation kit so I am not sure if it will be the same.
I had to notch the bottom of the relocation boxes. This was to clear the front contact bracket that goes under the front spring eyes. My boxes are wider than the frame rails so the side clearance was no issue.
Hope this helps.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Assassin bars and mini tub [Re: plycuda] #2598203
12/29/18 12:06 AM
12/29/18 12:06 AM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
I like the adjustability of the assassin bars but the more I look at the pictures it just doesn't look like they will fit inside the box on the frame unless I cut on it. I was trying to find a measurement across the front where the u bolts go over the leaf spring.
Re: Assassin bars and mini tub [Re: plycuda] #2598347
12/29/18 01:16 PM
12/29/18 01:16 PM
'murica
misfired Offline
misfired  Offline
'murica
The piece that is clamped around the spring also should come with a drill bit to put a hole through the spring and the clamp piece. So i don't see why you couldn't just drill a few bolts through the spring and not use the clamps then cut it down if Needed. Might not be great but food for thought
