Re: Assassin bars and mini tub
[Re: plycuda]
#2597408
12/27/18 01:47 AM
12/27/18 01:47 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I don't think they are any different than caltrakz
[Re: plycuda]
#2597790
12/27/18 10:50 PM
12/27/18 10:50 PM
Posts: 8,860 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Caltrac make one just for a mini tub setup. Something on the part that goes over the leaf spring is welded instead of bolted. The front mount is welded instead of a nut/bolt so it will fit in the confines of the front spring box when you move the springs inboard.
[Re: plycuda]
#2597820
12/28/18 12:07 AM
12/28/18 12:07 AM
Posts: 4,563 Motor City
6PKRTSE
Motor City
My rear leafs are moved inboard 3" to the frame rails. No issues with the old Mopar Performance kit and using Caltracs w/split mono's.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: plycuda]
#2597876
12/28/18 03:37 AM
12/28/18 03:37 AM
Posts: 1,505 TN
SCATPACK 1
TN
My cousin took off Cal tracs and went with the Assassin bars and did not have to make any changers to the spring hanger
Old Geezer Racing
[Re: SCATPACK 1]
#2597981
12/28/18 02:28 PM
12/28/18 02:28 PM
hemi-itis
My cousin took off Cal tracs and went with the Assassin bars and did not have to make any changers to the spring hanger Did you cousin pick up any?? I had to trim the boxes to fit the Cak Tracs....
[Re: plycuda]
#2598005
12/28/18 03:29 PM
12/28/18 03:29 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
I have a home made relocation kit so I am not sure if it will be the same. I had to notch the bottom of the relocation boxes. This was to clear the front contact bracket that goes under the front spring eyes. My boxes are wider than the frame rails so the side clearance was no issue. Hope this helps.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
