2008 Dodge caliber automatic transmission swap issue #2587408
12/05/18 11:13 AM
12/05/18 11:13 AM
Concord Twp. Ohio
62 crown Offline OP
62 crown  Offline OP
Concord Twp. Ohio
Hi guys, I just replaced an automatic transmission in an 08 caliber with a 2.0 engine. Everything went well, except the thing is in limp mode, and won't accelerate. It goes forward and backwards, basically at idle speed regardless if you put the pedal to the floor or not...I've read that it may need to be reprogrammed now. Is there a fix without taking it to the dealership ??
Thanks, Mike
62 Imperial Crown
63 Dodge 880
67 Satellite
69Roadrunner
70Roadrunner
78 Lil Red Express
81 Powerwagon
82 Grand Wagoneer
99 RAM 2500 4X4
08 RAM 2500 4X4
Re: 2008 Dodge caliber automatic transmission swap issue [Re: 62 crown] #2587421
12/05/18 11:46 AM
12/05/18 11:46 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Worth checking. Known problem with wiring harness.
wiring had rubbed on left frame rail where plastic splash guard covers the end of the transmission, repaired transmission worked perfectly - before repair you would swear it was burnt up
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: 2008 Dodge caliber automatic transmission swap issue [Re: 62 crown] #2587554
12/05/18 03:43 PM
12/05/18 03:43 PM
Guitar Jones Offline
What was the original problem/symptom you replaced the trans for?
Re: 2008 Dodge caliber automatic transmission swap issue [Re: 62 crown] #2587785
12/05/18 10:00 PM
12/05/18 10:00 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
The transmission and the tcm need to be calibrated for each other. You will have to take it to the dealer and have it programmed.
