Re: module in 1993 dakota right foot well??
[Re: flyman]
#2582918
11/25/18 06:53 PM
11/25/18 06:53 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: flyman]
#2583548
11/27/18 02:53 AM
11/27/18 02:53 AM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
That's the control module for an early generation anti-lock braking system for the rear brakes only. See: https://www.aa1car.com/library/abs_kelseyhayes_rwal.htm I have a 1991 Dak and either the module is bad or the ABS solenoid that is plumbed into the rear brake line is bad. The emergency brake light (red) stays on to indicate that there is a problem. You can use the paper clip trick to get the ABS Control unit to blink out the error code. Refurbished ABS control modules are available but a rebuilt solenoid valve with the electrical connector for your make and model Dak is hard to find. The little truck brakes work fine but there is no ABS action on the rear brake circuit. It's like driving old school
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: rumblefish72]
#2584018
11/28/18 02:10 AM
11/28/18 02:10 AM
Posts: 954 garnett kansas
rhad
garnett kansas
my 92 Dakota has RWAL and it has a valve on the rear of the frame near the axle that the brake line runs thru,i believe it should be removed /bypassed if your not going to use the RWAL system as im fairly sure its part of the antilock system
my ladder of success is missing some rungs
