Tic Toc Tach wiring? #2582480
11/24/18 06:34 PM
11/24/18 06:34 PM
New Mexico
JMCFAN Online content OP
JMCFAN  Online Content OP
New Mexico
For the harness... 4 connections. One to back of tach....one to fuse box. Other end one plug connector to the coil. There is a blade connector there as well.... where does it go...???
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Tic Toc Tach wiring? [Re: JMCFAN] #2582529
11/24/18 07:57 PM
11/24/18 07:57 PM
Ohio
lockjaw-express Offline
Ohio
JMCFAN,
I bought an OER Tic-Toc tac and it came with no instructions, and has a gray wire with a connector to be run to the fuse panel. There is also two grounds, and one that is market ā€œSā€ that that has an insulation washer under the blade connector, which I assume is the tach input...my dash was a real pain to remove!
I am going to replace the circuit board and a couple of switches while I am at it.
Do you have the original?
Regards, Mark
Re: Tic Toc Tach wiring? [Re: JMCFAN] #2582559
11/24/18 08:31 PM
11/24/18 08:31 PM
New Mexico
New Mexico
Yes it the original harness...
I think I have it. Blue wire...plug end to back of tach, other end to fuse box. Grey wire to tach...and through firewall to coil.
Re: Tic Toc Tach wiring? [Re: JMCFAN] #2582623
11/24/18 10:58 PM
11/24/18 10:58 PM
Ohio
Ohio
On my ā€˜68 Super Bee schematic, it shows the grey wire going to the fuse block...please check your schematic.
Mark
Re: Tic Toc Tach wiring? [Re: JMCFAN] #2582658
11/25/18 12:53 AM
11/25/18 12:53 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I would think the fact that the grey wire has a firewall plug on it would make it the wire to the coil.
Re: Tic Toc Tach wiring? [Re: JMCFAN] #2582673
11/25/18 02:28 AM
11/25/18 02:28 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
No. The Blue wire goes to the clock (stud). Other end of blue goes to fuse box constant hot. Grey to the tach (flat blade). Other end of grey to engine harness connection (coil).
Re: Tic Toc Tach wiring? [Re: JMCFAN] #2582703
11/25/18 03:44 AM
11/25/18 03:44 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'll give you what I have saved from install posts, see if it helps?....
ticktachtockchargerrt.JPGtictachtockchardgder.JPGtictachtockcharger.JPGtictachtockchargertt.JPG
Re: Tic Toc Tach wiring? [Re: DAYCLONA] #2582704
11/25/18 03:44 AM
11/25/18 03:44 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Tic Toc Tach wiring? [Re: DAYCLONA] #2582783
11/25/18 01:27 PM
11/25/18 01:27 PM
New Mexico
New Mexico
And ground here?
Re: Tic Toc Tach wiring? [Re: JMCFAN] #2582835
11/25/18 03:12 PM
11/25/18 03:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think the ground is through the body of the tach no other ground needed.
