Tic Toc Tach wiring?
#2582480
11/24/18 06:34 PM
11/24/18 06:34 PM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
For the harness... 4 connections. One to back of tach....one to fuse box. Other end one plug connector to the coil. There is a blade connector there as well.... where does it go...???
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: Tic Toc Tach wiring?
[Re: JMCFAN]
#2582529
11/24/18 07:57 PM
11/24/18 07:57 PM
Posts: 562 Ohio
lockjaw-express
Ohio
JMCFAN,
I bought an OER Tic-Toc tac and it came with no instructions, and has a gray wire with a connector to be run to the fuse panel. There is also two grounds, and one that is market āSā that that has an insulation washer under the blade connector, which I assume is the tach input...my dash was a real pain to remove!
I am going to replace the circuit board and a couple of switches while I am at it.
Do you have the original?
Regards, Mark
[Re: JMCFAN]
#2582559
11/24/18 08:31 PM
11/24/18 08:31 PM
JMCFAN
New Mexico
Yes it the original harness...
I think I have it. Blue wire...plug end to back of tach, other end to fuse box. Grey wire to tach...and through firewall to coil.
[Re: JMCFAN]
#2582703
11/25/18 03:44 AM
11/25/18 03:44 AM
Posts: 18,157 Mass
DAYCLONA
Mass
For the harness... 4 connections. One to back of tach....one to fuse box. Other end one plug connector to the coil. There is a blade connector there as well.... where does it go...??? I'll give you what I have saved from install posts, see if it helps?....
[Re: DAYCLONA]
#2582704
11/25/18 03:44 AM
11/25/18 03:44 AM
Posts: 18,157 Mass
DAYCLONA
Mass
