Page 1 of 4 1 2 3 4
Dart SB Mopar Blocks #2575864
11/08/18 02:05 PM
11/08/18 02:05 PM
warren, mich.
dwayne welder Offline OP
warren, mich.
I spent a couple hours with Richard Maskin yesterday and asked about a small Block Mopar block, right now there is NO possibility of doing one????? Maybe the new company that owns Dart will have to put feelers out there to see????
Re: Dart SB Mopar Blocks [Re: dwayne welder] #2575873
11/08/18 02:23 PM
11/08/18 02:23 PM
AndyF Offline
AndyF  Offline
If I owned Dart I'd do a cast iron low deck big block with 440 mains. I'd design the block to be run at 4.50 bore x 4.25 stroke. I'd also invest in a few matching low deck intakes. Then I'd sit back and take orders.
I wouldn't invest a dime into making SB parts.
Re: Dart SB Mopar Blocks [Re: AndyF] #2575887
11/08/18 02:42 PM
11/08/18 02:42 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
The small blocks would sell more than the big blocks I believe.
Re: Dart SB Mopar Blocks [Re: AndyF] #2575913
11/08/18 03:23 PM
11/08/18 03:23 PM
Washington
madscientist Offline
Washington
Bob Book would disagree with you.
With turbos and such, a 400ish inch SB will compete with most everything under the big bore space hemi and the 481X stuff.
On small tires, the SB would be easier to tune, lighter and take up much less space in the engine bay.
Won't happen though. I suspect the Ritter is close enough that 1-2 more iterations and the block would work. Look how much farther ahead the Ritter block is than the Dart, which is just an idea right now.
Re: Dart SB Mopar Blocks [Re: dwayne welder] #2575914
11/08/18 03:24 PM
11/08/18 03:24 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
With the supply of Magnum blocks out there in yards, I'd guess it'll be another decade before there is a business case the aftermarket can make work.
Who knows, by that time us small block guys may largely have gone Gen III leaving a tinier space for aftermarket LA blocks.
Re: Dart SB Mopar Blocks [Re: BcudaChris] #2575915
11/08/18 03:26 PM
11/08/18 03:26 PM
Washington
Washington
Comparing a magnum block to a race block is like comparing an anchor to a pillow. It's rediculous.
Re: Dart SB Mopar Blocks [Re: madscientist] #2575927
11/08/18 03:44 PM
11/08/18 03:44 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
personally I think it's more like comparing a cast iron block to a plastic mock up block..
As much as I like the G3 Hemi, reality is if there was availability of new race blocks at a competitive price to the Factory BGE block, the small block is going to be the 1st choice for a max effort build.
it's narrow, more after market parts, Cams , rocker systems more used aftermarket parts. better header to chassis fit. Weight is about the same as the G3 but lets face it there are more proven combinations for the SBM.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Dart SB Mopar Blocks [Re: ric3xrt] #2575934
11/08/18 03:56 PM
11/08/18 03:56 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Our problem is number one guys are cheap. Not just Mopar guys but most racers. Number two the factory stock LA block is strong enough to run 9.50’s-10.0’s at 3000 pounds and most aren’t even pushing them to that point. Why spend 5000.00 for a block for cars running slower than they are already capable of.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dart SB Mopar Blocks [Re: AndyF] #2575936
11/08/18 03:59 PM
11/08/18 03:59 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yep, making money VS. making horsepower, can't debate that one.
Business vs. "Passion".
By now everyone knows a small block mopar can run it's @$$ off.
Often times harder than most anything else comparable.
But, try selling parts for them + comparable parts for other Mopar engines for 20+ years or so. I found out real quick, Big block parts far outsell small block parts. Doesn't matter what the commodity is. Even Gen 2 426 hemi parts outsell small block. At one time i believed it might change over time....but the market has shown me it has not.
Rich H.
Esse Quam Videri
Re: Dart SB Mopar Blocks [Re: madscientist] #2575953
11/08/18 04:51 PM
11/08/18 04:51 PM
BcudaChris Offline
BcudaChris  Offline
As may be. The market will decide though, not some dude who can't/won't spell properly but uses cute similes.
Re: Dart SB Mopar Blocks [Re: BcudaChris] #2575967
11/08/18 05:25 PM
11/08/18 05:25 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Exactly.
Trick Flow is coming to market with Small block heads and intake. I doubt they figured wrong.
Bunch of small block haters on here sometimes
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Dart SB Mopar Blocks [Re: dwayne welder] #2575971
11/08/18 05:39 PM
11/08/18 05:39 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I've got a NOS Siamese 59 degree (Siamese 340 replacement) sitting at home next to my tractor doing me no good. It will go up for sale pretty soon, I just need to set aside few hours to get out there,jockey stuff around, and blow the dust off it. It's been hard to find the time with other projects and the rest of life happening. Need max exposure so, all I can say is keep an eye on eBay.
Rich H.
Esse Quam Videri
Re: Dart SB Mopar Blocks [Re: ZIPPY] #2575972
11/08/18 05:50 PM
11/08/18 05:50 PM
PA.
"Little"John
"Little"John
PA.
I’ll give you 200.00 for it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Dart SB Mopar Blocks [Re: pittsburghracer] #2575975
11/08/18 06:06 PM
11/08/18 06:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Some of the fastest Mopar door cars I have seen at our track are smallblocks built with W series heads.
Re: Dart SB Mopar Blocks [Re: dwayne welder] #2575979
11/08/18 06:12 PM
11/08/18 06:12 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
$250 and a standard bore 340 core block. callme
Re: Dart SB Mopar Blocks [Re: pittsburghracer] #2575983
11/08/18 06:18 PM
11/08/18 06:18 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Cheap skate! I'll give $300, shipped.
Re: Dart SB Mopar Blocks [Re: dwayne welder] #2575984
11/08/18 06:20 PM
11/08/18 06:20 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Bidding starts at fitty cent.
Re: Dart SB Mopar Blocks [Re: BcudaChris] #2575985
11/08/18 06:25 PM
11/08/18 06:25 PM
Washington
Washington
What exactly did I spell incorrectly? Also, I don't smile, why would I use one in a post?
I stand by what I said. A magnum block is not a race block, nor will it ever be a race block.
Re: Dart SB Mopar Blocks [Re: justinp61] #2575986
11/08/18 06:25 PM
11/08/18 06:25 PM
Washington
Washington
I'm it at 500.00 and I'll pay the shipping.
Re: Dart SB Mopar Blocks [Re: madscientist] #2575993
11/08/18 06:39 PM
11/08/18 06:39 PM
PA.
"Little"John
"Little"John
PA.
I’m out!!!
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Page 1 of 4 1 2 3 4
