Low deck limit for a stroker crank #2575195
11/07/18 05:47 AM
11/07/18 05:47 AM
Yakima, WA
K
kevinlc Offline OP
kevinlc  Offline OP
K
Yakima, WA
Will a 4.375 need minor clearancing with a stock cam location. This will be for an indy block. I'm looking to get a new assembly. Thanks.
Re: Low deck limit for a stroker crank [Re: kevinlc] #2575229
11/07/18 11:07 AM
11/07/18 11:07 AM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
I have a 4.30 and I know of a few 4.5 stroke low deck indy combos
Re: Low deck limit for a stroker crank [Re: kevinlc] #2575249
11/07/18 11:57 AM
11/07/18 11:57 AM
gregsdart Offline
gregsdart  Offline
There are a lot of rod options now days. If there is a steel rod with a 2.100 sbc size bearing, that would really help. Custom aluminum rods can be had that way, but being fatter than steel, might not gain much clearance. Rod/stroke ratio and compression height rear thier ugly head at 4.5 stroke. Look at big block chev combos for evidence of what can be done. With a stock deck of 9.8 and a tall deck of 10.2, what the best engine builders are selling, like Shaforof or ReherMorrison should tell a tale.
Re: Low deck limit for a stroker crank [Re: kevinlc] #2575292
11/07/18 01:09 PM
11/07/18 01:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
We freshened a 526 (4.375 x 4.375) out of a mud racer about a year ago....... it all seemed to fit okay.
Re: Low deck limit for a stroker crank [Re: kevinlc] #2575296
11/07/18 01:25 PM
11/07/18 01:25 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
I have a 4.500 crank in my block,bme rods 6.53,chevy rod ends,venolia pistos flat tops
Re: Low deck limit for a stroker crank [Re: kevinlc] #2575401
11/07/18 04:10 PM
11/07/18 04:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Our dragster had a 572" low deck. One thing that needs to be paid close attention to is clearance between crank throw and piston/rod. Make sure there is proper clearance for the rods and the cranks counterweights. If aluminum make sure you have a relief on each side of the small end. It gets tight but it fits. Ours had a KB Raised cam block
