Re: Low deck limit for a stroker crank
[Re: kevinlc]
#2575249
11/07/18 11:57 AM
11/07/18 11:57 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
There are a lot of rod options now days. If there is a steel rod with a 2.100 sbc size bearing, that would really help. Custom aluminum rods can be had that way, but being fatter than steel, might not gain much clearance. Rod/stroke ratio and compression height rear thier ugly head at 4.5 stroke. Look at big block chev combos for evidence of what can be done. With a stock deck of 9.8 and a tall deck of 10.2, what the best engine builders are selling, like Shaforof or ReherMorrison should tell a tale.
[Re: kevinlc]
#2575292
11/07/18 01:09 PM
11/07/18 01:09 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
We freshened a 526 (4.375 x 4.375) out of a mud racer about a year ago....... it all seemed to fit okay.
[Re: kevinlc]
#2575401
11/07/18 04:10 PM
11/07/18 04:10 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Our dragster had a 572" low deck. One thing that needs to be paid close attention to is clearance between crank throw and piston/rod. Make sure there is proper clearance for the rods and the cranks counterweights. If aluminum make sure you have a relief on each side of the small end. It gets tight but it fits. Ours had a KB Raised cam block
