Good places to get a driveshaft? #2574686
11/06/18 01:33 AM
11/06/18 01:33 AM
long time lurker, short time p...
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
Looking for recommendations
Re: Good places to get a driveshaft? [Re: PorkyPig] #2574701
11/06/18 02:09 AM
11/06/18 02:09 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I got mine from DR DIFF made by Strange
Re: Good places to get a driveshaft? [Re: PorkyPig] #2574721
11/06/18 03:45 AM
11/06/18 03:45 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Dr Diff
Ok
Re: Good places to get a driveshaft? [Re: PorkyPig] #2574722
11/06/18 04:00 AM
11/06/18 04:00 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Strange has been great over many units.
Re: Good places to get a driveshaft? [Re: PorkyPig] #2574735
11/06/18 09:10 AM
11/06/18 09:10 AM
Georgia and Washington
JMCarter Offline
JMCarter  Offline
Ordered mine from Mark Williams and was very satisfied. You get all the build documentation as well, including the balance info.
Re: Good places to get a driveshaft? [Re: PorkyPig] #2574737
11/06/18 09:44 AM
11/06/18 09:44 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
My last one was from Driveshaft Shop. Dr Diff is great to use.
Re: Good places to get a driveshaft? [Re: PorkyPig] #2574771
11/06/18 11:52 AM
11/06/18 11:52 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
OVC industries, or called Victory performance, they sponsor the Victory nostalgia super stock series. Dennis Mothershed is the man to talk to.
http://www.buzzfile.com/business/Ovc-Industries-Inc-515-282-9996
Re: Good places to get a driveshaft? [Re: CSK] #2574788
11/06/18 12:33 PM
11/06/18 12:33 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Me too. About to order another from the good Doc. iagree
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Good places to get a driveshaft? [Re: PorkyPig] #2574796
11/06/18 12:42 PM
11/06/18 12:42 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I got mine from Dennys Driveshafts.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Good places to get a driveshaft? [Re: PorkyPig] #2574892
11/06/18 03:56 PM
11/06/18 03:56 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I get steel from Strange and I've used aluminum shafts from Dynatech that worked fine, although it's been a while and I've heard they may have delayed delivery issues. Mark Williams is top shelf too. I would likely use MW or Inland Empire for aluminum.
I've used steel shafts from a local shop that builds truck shafts and does a good job, but these were street driven, OE replacement type units. Big difference between that and a shaft in a race car that may see 800HP and spin 7000+ RPM.
Re: Good places to get a driveshaft? [Re: PorkyPig] #2575171
11/07/18 02:46 AM
11/07/18 02:46 AM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I bought one from Mancinis years ago (was dropped shipped from some place in IA I think), it was horrible. Had a vibration that finally went away when it broke the tail housing on my trans.
Replaced the housing and on recommendation from others here I took my DS to Dynotech. I needed it in a hurry and in 2 days I had it back. They told me the balance and run-out were way off (like a banana they said) and the u-joint's were not good either (poor quality 1350's)
They charged me $120 to rebuild my DS, this included straightening, balancing and the new u-joints. Never had any issue since, would use again.
https://www.dynotechengineering.com/
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Good places to get a driveshaft? [Re: PorkyPig] #2575189
11/07/18 03:43 AM
11/07/18 03:43 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Travis at Mark Williams Ent.
Re: Good places to get a driveshaft? [Re: Dave Hall] #2575210
11/07/18 09:04 AM
11/07/18 09:04 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Another vote for Strange from Dr. Diff.
I'd had a lot of issues with breakage with the smaller u-joints and tearing up the front yoke at the starting line was the last straw. The local shop were complete morons about helping me so I went to Cass's website per the advice on here.
I had it within a few days of ordering. Not only has it lasted at that level, but we have been spraying another 150 hp on top of that!
'63 Dodge 330
11.19 @ 121 mph
Re: Good places to get a driveshaft? [Re: PorkyPig] #2575231
11/07/18 11:21 AM
11/07/18 11:21 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
When I installed the Dana in my car I ordered a new driveshaft from Dynotech. The first one was short so it went back and the next one was the right length. After the mini tub, narrowed Dana and new driveshaft install the car always had a vibration. I tried different pinion angles and nothing helped so this past spring I took the driveshaft to my local shop and had it checked. The run out was good but the balance was way off. My next one will come from Strange or Mark Williams.
Re: Good places to get a driveshaft? [Re: PorkyPig] #2575234
11/07/18 11:36 AM
11/07/18 11:36 AM
Canada
onig Offline
onig  Offline
Canada
Who is using a carbon fiber shaft?
How much more expensive is it over a steel unit?
69 Dart
Re: Good places to get a driveshaft? [Re: GY3] #2575332
11/07/18 02:40 PM
11/07/18 02:40 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Originally Posted By GY3
The local shop were complete morons...
There are two local shops here in Portland that I know of and I highly recommend NOT using either one if you want quality work.
That said, I can't remember the last time I saw a driveshaft failure at the track. They seem to be up to the job as far as I can tell.
twocents
Re: Good places to get a driveshaft? [Re: GY3] #2575412
11/07/18 04:23 PM
11/07/18 04:23 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I bought my Strange S-60 from Dr. Diff and plan to get a matching driveshaft from him when I can get the final measurements.
That said, I was running an OEM driveshaft w/ HD 7290 u-joints and a local shop's balance job going mid-10s at 3700#s and had no problems at all. You saying: "I'd had a lot of issues with breakage with the smaller u-joints < Do you mean smaller than 7290s? > and tearing up the front yoke at the starting line was the last straw" makes me wonder if there was something else wrong than simply because it was an OEM driveshaft.
Re: Good places to get a driveshaft? [Re: @#$%&*!] #2575416
11/07/18 04:27 PM
11/07/18 04:27 PM
BradH Offline
BradH  Offline
Originally Posted By @#$%&*!
... I can't remember the last time I saw a driveshaft failure at the track. They seem to be up to the job as far as I can tell.
twocents
I have seen an OEM driveshaft twisted like a pretzel by a car where the owner probably spent "big" on his N2O system and "not so big" on chassis improvements to handle it.
Re: Good places to get a driveshaft? [Re: PorkyPig] #2575425
11/07/18 04:38 PM
11/07/18 04:38 PM
an8sec70cuda Offline
Local big truck and driveline shop (Sheppard's Truck Service in Florence, SC) makes mine for me. Never had a problem w/ them. 3" diameter shaft in a 3900 lb 8 sec car.
I twisted 2 stock Mopar driveshafts running high 10s at 3700 lbs.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Good places to get a driveshaft? [Re: PorkyPig] #2575428
11/07/18 04:43 PM
11/07/18 04:43 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mark Williams..
