Re: Good places to get a driveshaft?
[Re: PorkyPig]
#2574701
11/06/18 02:09 AM
11/06/18 02:09 AM
Posts: 2,860 Pattison Texas
CSK
Pattison Texas
I got mine from DR DIFF made by Strange
[Re: CSK]
#2574788
11/06/18 12:33 PM
11/06/18 12:33 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I got mine from DR DIFF made by Strange Me too. About to order another from the good Doc.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: PorkyPig]
#2574796
11/06/18 12:42 PM
11/06/18 12:42 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I got mine from Dennys Driveshafts.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: PorkyPig]
#2574892
11/06/18 03:56 PM
11/06/18 03:56 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I get steel from Strange and I've used aluminum shafts from Dynatech that worked fine, although it's been a while and I've heard they may have delayed delivery issues. Mark Williams is top shelf too. I would likely use MW or Inland Empire for aluminum.
I've used steel shafts from a local shop that builds truck shafts and does a good job, but these were street driven, OE replacement type units. Big difference between that and a shaft in a race car that may see 800HP and spin 7000+ RPM.
[Re: PorkyPig]
#2575171
11/07/18 02:46 AM
11/07/18 02:46 AM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
I bought one from Mancinis years ago (was dropped shipped from some place in IA I think), it was horrible. Had a vibration that finally went away when it broke the tail housing on my trans. Replaced the housing and on recommendation from others here I took my DS to Dynotech. I needed it in a hurry and in 2 days I had it back. They told me the balance and run-out were way off (like a banana they said) and the u-joint's were not good either (poor quality 1350's) They charged me $120 to rebuild my DS, this included straightening, balancing and the new u-joints. Never had any issue since, would use again. https://www.dynotechengineering.com/
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: Dave Hall]
#2575210
11/07/18 09:04 AM
11/07/18 09:04 AM
Posts: 4,674 Wichita
GY3
Wichita
Another vote for Strange from Dr. Diff.
I'd had a lot of issues with breakage with the smaller u-joints and tearing up the front yoke at the starting line was the last straw. The local shop were complete morons about helping me so I went to Cass's website per the advice on here.
I had it within a few days of ordering. Not only has it lasted at that level, but we have been spraying another 150 hp on top of that!
[Re: PorkyPig]
#2575234
11/07/18 11:36 AM
11/07/18 11:36 AM
Posts: 361 Canada
onig
Canada
Who is using a carbon fiber shaft? How much more expensive is it over a steel unit?
69 Dart
[Re: GY3]
#2575332
11/07/18 02:40 PM
11/07/18 02:40 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
... The local shop were complete morons... There are two local shops here in Portland that I know of and I highly recommend NOT using either one if you want quality work. That said, I can't remember the last time I saw a driveshaft failure at the track. They seem to be up to the job as far as I can tell.
[Re: GY3]
#2575412
11/07/18 04:23 PM
11/07/18 04:23 PM
BradH
I had it within a few days of ordering. Not only has it lasted at that level, but we have been spraying another 150 hp on top of that! I bought my Strange S-60 from Dr. Diff and plan to get a matching driveshaft from him when I can get the final measurements. That said, I was running an OEM driveshaft w/ HD 7290 u-joints and a local shop's balance job going mid-10s at 3700#s and had no problems at all. You saying: "I'd had a lot of issues with breakage with the smaller u-joints < Do you mean smaller than 7290s? > and tearing up the front yoke at the starting line was the last straw" makes me wonder if there was something else wrong than simply because it was an OEM driveshaft.
[Re: PorkyPig]
#2575425
11/07/18 04:38 PM
11/07/18 04:38 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Local big truck and driveline shop (Sheppard's Truck Service in Florence, SC) makes mine for me. Never had a problem w/ them. 3" diameter shaft in a 3900 lb 8 sec car.
I twisted 2 stock Mopar driveshafts running high 10s at 3700 lbs.
