Re: Feedback using Evapo-Rust Wanted
[Re: vinnyd76]
#2572619
11/01/18 03:29 PM
11/01/18 03:29 PM
Posts: 3,081 Michigan
A727Tflite
Talk about timing.
I had two heads built up waiting to finish up the short block and had an issue with the crank. Heads sat almost a month and got flash rust on them.
Took them apart and soaked them in a plastic tote and the Evaporust made them good as new.
[Re: A727Tflite]
#2572622
11/01/18 03:38 PM
11/01/18 03:38 PM
Posts: 5,360 Rancho Cordova, California (Sa...
hemi71x
Been using Evaporust for around 10 years now. Stuff works great. My suspension parts come out looking like this from a 5 gallon container of the product. Get your parts clean of all the grease and grime, with the cleaning solution of your choosing, and let them soak.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: Neil]
#2572736
11/01/18 08:13 PM
11/01/18 08:13 PM
hemi71x
Parts soaked in sunlight come clean faster. I never heard that one about Evaporust before. Why would that be? Guess i'm never going to find out, as i soak out parts overnight, then into the morning, if need be.
[Re: DrCharles]
#2572826
11/01/18 11:43 PM
11/01/18 11:43 PM
Posts: 4,727 Moved to N.E. Tennessee
GomangoCuda
Anybody use the molasses method? I think it's supposed to work faster when heated.
[Re: GomangoCuda]
#2572835
11/02/18 12:00 AM
11/02/18 12:00 AM
Posts: 1,836 South Bend
John Brown
South Bend
Anybody use the molasses method? I think it's supposed to work faster when heated. From my early chemistry class days, I seem to recall that a 10° Centigrade temperature increase (same as 18° F increase) doubles the speed of most chemical reactions.
[Re: John Brown]
#2572848
11/02/18 12:30 AM
11/02/18 12:30 AM
hemi71x
[/quote]From my early chemistry class days, I seem to recall that a 10° Centigrade temperature increase (same as 18° F increase) doubles the speed of most chemical reactions. [/quote]
Learn something new every day. But tomorrow morning i'm going to forget two things, old.
[Re: hemi71x]
#2572887
11/02/18 03:37 AM
11/02/18 03:37 AM
A727Tflite
From my early chemistry class days, I seem to recall that a 10° Centigrade temperature increase (same as 18° F increase) doubles the speed of most chemical reactions. [/quote] Learn something new every day. But tomorrow morning i'm going to forget two things, old.[/quote] Now that is hilarious. And so true. I’m so old I told the wife to stop buying green bananas.
[Re: vinnyd76]
#2572894
11/02/18 04:42 AM
11/02/18 04:42 AM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
I've used Evaporust for years and years, it's awesome. I just bought another 13.2 litre pail today for $59.99 Canadian.
CrAzYMoPaRGuY
[Re: vinnyd76]
#2572968
11/02/18 12:05 PM
11/02/18 12:05 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
Evaporust contains acid. Acid will eat rust first, but will also start to eat metals after that.
For me personally, I would have no problem at all using it on the outside of a rear end "pumpkin". Since the cast iron is so thick, it wouldn't hurt a thing. I would also soak the gears inside the pumpkin, but not leave it in the Evaporust too long (maybe an hour or two) so that I didn't eat away very much of the important metal inside the pumpkin. My 2-cents.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
