Feedback using Evapo-Rust Wanted #2572596
11/01/18 02:30 PM
11/01/18 02:30 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone have a good/bad experience using Evapo-Rust product? Looking to clean up a center section of a rear axle assembly. I was told to use the product, but wanted to obtain some feedback from the forum.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2572610
11/01/18 02:52 PM
11/01/18 02:52 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The stuff is absolutely awesome but you need to be careful with it.
It will remove rust but it will also remove other things like galvonizing.
Also it will leech through some plastic containers.
It's best to check on your parts as they soak, don't leave them in it too long.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2572619
11/01/18 03:29 PM
11/01/18 03:29 PM
A727Tflite Online content
A727Tflite  Online Content
Talk about timing.
I had two heads built up waiting to finish up the short block and had an issue with the crank.
Heads sat almost a month and got flash rust on them.
Took them apart and soaked them in a plastic tote and the Evaporust made them good as new.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2572620
11/01/18 03:35 PM
11/01/18 03:35 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If at all possible, submerge the entire part in the EvapoRust. If some of the piece is sticking out of the solution, an etching line can be created. If you must have a section of the part sticking out of the solution, you can put paper towels/shop towels around the part at the water line. This will help stop any etching line from forming.
Also, I soaked one of my window mechanisms in it. The spring on the mechanism had a lot of surface rust on it. After removing the mechanism from the EvapoRust, the spring was cracked. Those are the only two issues I've had with it. If you leave it submerged too long, it will remove factory paint markings when you rinse it off.
About a month ago, I cleaned up an 8 3/4 center section with it. I wish someone made a heavy duty plastic "form" that the center section would fit into. Then you would only need a small amount of EvapoRust to completely cover the part. You need a lot of product to cover a center section if you are using a bucket.
Re: Feedback using Evapo-Rust Wanted [Re: A727Tflite] #2572622
11/01/18 03:38 PM
11/01/18 03:38 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
Been using Evaporust for around 10 years now.
Stuff works great.
My suspension parts come out looking like this from a 5 gallon container of the product.
Get your parts clean of all the grease and grime, with the cleaning solution of your choosing, and let them soak.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Feedback using Evapo-Rust Wanted [Re: hemi71x] #2572644
11/01/18 04:24 PM
11/01/18 04:24 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Parts soaked in sunlight come clean faster.
I put odd shaped parts in a plastic bag and then put the bag in a coffee can or whatever fits and then put stones, wood, or whatever I can find around the outside to fill up the void space. This uses less Evaporust than just filling the whole container up
It will bleach out plastic parts and heater box housings.
You can run it thru a paint strainer and re-use it.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2572665
11/01/18 05:14 PM
11/01/18 05:14 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I've seen guys use electrolysis on table saw tables by soaking a rag in the solution and then covering with plastic wrap. no need to submerge. Will Evoporust work that way if you keep it wet enough? I'd like to do my rearend housing this winter.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2572688
11/01/18 05:53 PM
11/01/18 05:53 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: Feedback using Evapo-Rust Wanted [Re: Alaskan_TA] #2572732
11/01/18 07:54 PM
11/01/18 07:54 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Evaporust works well if you can submerge the item but for large items I like to use a recirculating bath to continually wash over the part. The product for this is similar to Evaporust but has a thinner consistancy and is better for pumping. www.safestrustremover.com
Re: Feedback using Evapo-Rust Wanted [Re: Neil] #2572736
11/01/18 08:13 PM
11/01/18 08:13 PM
I never heard that one about Evaporust before.
Why would that be? shruggy
Guess i'm never going to find out, as i soak out parts overnight, then into the morning, if need be.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2572745
11/01/18 08:37 PM
11/01/18 08:37 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Sunlight removes rust?
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2572763
11/01/18 09:24 PM
11/01/18 09:24 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Sunlight has lots of infrared radiation. That makes the container and solution hotter. Maybe the chemical reaction proceeds faster at elevated temperatures? shruggy
Re: Feedback using Evapo-Rust Wanted [Re: DrCharles] #2572816
11/01/18 11:24 PM
11/01/18 11:24 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Yes, while I have not gone so far as to record the time it takes to clean something in the shade vs in direct sunlight it does seem to work faster when left out in the sun on a warm day. I have a stainless steel pot I sometimes use and the sun warms the metal pot up pretty fast, which raises the temperature of the Evaporust.
I've let things soak inside before and it always seems to take a little longer.
Re: Feedback using Evapo-Rust Wanted [Re: DrCharles] #2572826
11/01/18 11:43 PM
11/01/18 11:43 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Anybody use the molasses method? I think it's supposed to work faster when heated.
Re: Feedback using Evapo-Rust Wanted [Re: GomangoCuda] #2572835
11/02/18 12:00 AM
11/02/18 12:00 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
From my early chemistry class days, I seem to recall that a 10° Centigrade temperature increase (same as 18° F increase) doubles the speed of most chemical reactions.
Re: Feedback using Evapo-Rust Wanted [Re: John Brown] #2572848
11/02/18 12:30 AM
11/02/18 12:30 AM
[/quote]From my early chemistry class days, I seem to recall that a 10° Centigrade temperature increase (same as 18° F increase) doubles the speed of most chemical reactions. [/quote]
Learn something new every day.
But tomorrow morning i'm going to forget two things, old.
Re: Feedback using Evapo-Rust Wanted [Re: hemi71x] #2572887
11/02/18 03:37 AM
11/02/18 03:37 AM
But tomorrow morning i'm going to forget two things, old.[/quote]
Now that is hilarious. And so true.
I’m so old I told the wife to stop buying green bananas.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2572894
11/02/18 04:42 AM
11/02/18 04:42 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I've used Evaporust for years and years, it's awesome. I just bought another 13.2 litre pail today for $59.99 Canadian.
CrAzYMoPaRGuY
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2572902
11/02/18 06:34 AM
11/02/18 06:34 AM
Melbourne
O
ossietim Offline
ossietim  Offline
O
Melbourne
Yes all these solutions work better with elevated temps.(15-20* ) quick (35-50*)very active.
I use safest rust remover (but I make my own as I know the formula)
Evaporust has sulphur (hence the yellowish colour)
Molasses is slow but very effective.
Re: Feedback using Evapo-Rust Wanted [Re: vinnyd76] #2572968
11/02/18 12:05 PM
11/02/18 12:05 PM
Chicago
PurpleBeeper Offline
Chicago
Evaporust contains acid. Acid will eat rust first, but will also start to eat metals after that.
For me personally, I would have no problem at all using it on the outside of a rear end "pumpkin". Since the cast iron is so thick, it wouldn't hurt a thing. I would also soak the gears inside the pumpkin, but not leave it in the Evaporust too long (maybe an hour or two) so that I didn't eat away very much of the important metal inside the pumpkin. My 2-cents.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
