1976 Dodge Charger 400-4v #2558915
10/04/18 02:41 PM
10/04/18 02:41 PM
Las Vegas Nevada
Aliso Offline OP
Aliso  Offline OP
Las Vegas Nevada
Hello i recently purchased a 1976 Dodge Charger 400-4v and I’ve had the hardest time trying to figure out parts engine and everything I been searching to understand car better
I recently just changed carburetor to a edelbrock 750 but the electric lean burning system doesn’t fit around the carburetor without hitting I’m looking to change it and take it off can you guys tell me what I will need to do the conversion
Re: 1976 Dodge Charger 400-4v [Re: Aliso] #2559051
10/04/18 08:41 PM
10/04/18 08:41 PM
Courtenay, B.C.
DarrenS Offline
DarrenS  Offline
Courtenay, B.C.
Hi.
So it had a lean burn carb. Does the distributor have a vacuum advance can? Does it have an ECU on the firewall?
Re: 1976 Dodge Charger 400-4v [Re: Aliso] #2559144
10/04/18 11:48 PM
10/04/18 11:48 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
In order to remove the lean burn, you need an electronic distributor, an ecu, a ballast resistor and a wiring harness. MP used to sell a kit but I think it's now discontinued. Summit Racing had their own version of the kit. Theirs might still be available.
You should easily be able to find those components separately if you need to.
Re: 1976 Dodge Charger 400-4v [Re: DarrenS] #2559384
10/05/18 01:25 PM
10/05/18 01:25 PM
Las Vegas Nevada
Aliso Offline OP
Aliso  Offline OP
Las Vegas Nevada
Doesn’t have vaccum
Re: 1976 Dodge Charger 400-4v [Re: Aliso] #2559424
10/05/18 02:20 PM
10/05/18 02:20 PM
moparx Offline
moparx  Offline
aliso, a lean burn distributor did not have a vacuum can on the distributor, nor advance weights inside the housing. the "box" on the side of the aircleaner housing did all of the ignition functions. just think of the distributor as a spark router to the plugs as it's only function. as said above, you need a different distributor, ecu box, and the simple wiring harness that goes with it. or even a simple points distributor will work, and is even easier to hook up.
beer
Re: 1976 Dodge Charger 400-4v [Re: Aliso] #2559425
10/05/18 02:23 PM
10/05/18 02:23 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
Re: 1976 Dodge Charger 400-4v [Re: cudaboy] #2559437
10/05/18 02:43 PM
10/05/18 02:43 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
That PN# Dennis listed is for a small block, the OP has a 400 B engine.
the correct PN# from Jegs is: part Number: 555-40504K
which includes ballast resistor, electronic distributor, ecu, and harness...for $223.86 & free shipping.
Plymouth Makes It!
Re: 1976 Dodge Charger 400-4v [Re: Aliso] #2559448
10/05/18 02:50 PM
10/05/18 02:50 PM
P
Paul_Fancsali Offline
P
Just get a reman point dist and get a pertonix conversion kit you will even have vac advance
Re: 1976 Dodge Charger 400-4v [Re: Paul_Fancsali] #2559821
10/06/18 12:08 PM
10/06/18 12:08 PM
moparx Offline
moparx  Offline
iagree easiest, cheapest, best answer.
beer
Re: 1976 Dodge Charger 400-4v [Re: RoadRunnerLuva] #2570617
10/28/18 03:34 PM
10/28/18 03:34 PM
Las Vegas Nevada
Aliso Offline OP
Aliso  Offline OP
Las Vegas Nevada
My engine is 400 b body
Re: 1976 Dodge Charger 400-4v [Re: Aliso] #2570640
10/28/18 04:22 PM
10/28/18 04:22 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
A lot of people don't care for the "orange box". Some years were problematic.
I think this is a great option at good price, good seller, semi-stock look. $143.00
https://www.ebay.com/itm/MOPAR-440-Hi-Re...h/223172273418?
Facts are stubborn things.
Re: 1976 Dodge Charger 400-4v [Re: moparx] #2570658
10/28/18 05:21 PM
10/28/18 05:21 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
beer
I have to agree with this as well.
There is also a one wire HEI type distributor out there, if that trips the trigger...
I have mechanical Aptitude.
I can screw up anything.
Re: 1976 Dodge Charger 400-4v [Re: Aliso] #2570678
10/28/18 06:57 PM
10/28/18 06:57 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I could not remember what a 76 charger looked like, kind of big old ride.
Have a great day
Iowan
"obsolete is neat"
Re: 1976 Dodge Charger 400-4v [Re: Iowan] #2570683
10/28/18 07:27 PM
10/28/18 07:27 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
If I recall right, 76 Charger is basically a Cordoba. I've converted several Lean Burn cars to electronic ignition and it is just a matter of connecting 2 or 3 wires, mounting the ecu and installing the dist. Pretty simple to do.
Re: 1976 Dodge Charger 400-4v [Re: larrymopar360] #2570687
10/28/18 07:43 PM
10/28/18 07:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you go this route make sure you get the 383/400 kit, not the 440 kit as the RB distributor will not fit a B block. the shaft is too tall.
Don't be the exception.
Re: 1976 Dodge Charger 400-4v [Re: elmor353] #2570688
10/28/18 07:44 PM
10/28/18 07:44 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Both the Charger and the Charger s/e are both B bodies in 76, but had different sheet metal from one to the other.
Re: 1976 Dodge Charger 400-4v [Re: buildanother] #2570844
10/29/18 02:05 AM
10/29/18 02:05 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
True the standard Charger looks like the Dodge Coronet/Plymouth Fury of the era where the SE shares Cordoba sheetmetal.
Re: 1976 Dodge Charger 400-4v [Re: buildanother] #2571094
10/29/18 05:10 PM
10/29/18 05:10 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thank you for that information, I thought they used the same ignition.
Re: 1976 Dodge Charger 400-4v [Re: larrymopar360] #2571126
10/29/18 06:08 PM
10/29/18 06:08 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
'76 Charger from brochure
Re: 1976 Dodge Charger 400-4v [Re: larrymopar360] #2571127
10/29/18 06:11 PM
10/29/18 06:11 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I'd own one, especially with a 400-4V
