Re: 1976 Dodge Charger 400-4v
[Re: cudaboy]
#2559437
10/05/18 02:43 PM
10/05/18 02:43 PM
Posts: 5,324 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
That PN# Dennis listed is for a small block, the OP has a 400 B engine. the correct PN# from Jegs is: part Number: 555-40504K which includes ballast resistor, electronic distributor, ecu, and harness...for $223.86 & free shipping.
Plymouth Makes It!
[Re: moparx]
#2570658
10/28/18 05:21 PM
10/28/18 05:21 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Just get a reman point dist and get a pertonix conversion kit you will even have vac advance easiest, cheapest, best answer. I have to agree with this as well. There is also a one wire HEI type distributor out there, if that trips the trigger...
I have mechanical Aptitude. I can screw up anything.
[Re: Aliso]
#2570678
10/28/18 06:57 PM
10/28/18 06:57 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I could not remember what a 76 charger looked like, kind of big old ride.
Have a great day Iowan
"obsolete is neat"
[Re: larrymopar360]
#2570687
10/28/18 07:43 PM
10/28/18 07:43 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you go this route make sure you get the 383/400 kit, not the 440 kit as the RB distributor will not fit a B block. the shaft is too tall.
[Re: elmor353]
#2570688
10/28/18 07:44 PM
10/28/18 07:44 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
Both the Charger and the Charger s/e are both B bodies in 76, but had different sheet metal from one to the other.
[Re: buildanother]
#2570844
10/29/18 02:05 AM
10/29/18 02:05 AM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Both the Charger and the Charger s/e are both B bodies in 76, but had different sheet metal from one to the other. True the standard Charger looks like the Dodge Coronet/Plymouth Fury of the era where the SE shares Cordoba sheetmetal.
[Re: buildanother]
#2571094
10/29/18 05:10 PM
10/29/18 05:10 PM
Posts: 15,875 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Both the Charger and the Charger s/e are both B bodies in 76, but had different sheet metal from one to the other. Thank you for that information, I thought they used the same ignition.
Facts are stubborn things.
