Main dowel for "World" block, source? #2566972
10/20/18 04:36 PM
10/20/18 04:36 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I'm working with a used block that has a damaged dowel on one of the mains. Looks like 5/8 od. Anyone have a source other than Mitchell?
Rich H.
Esse Quam Videri
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2566993
10/20/18 05:35 PM
10/20/18 05:35 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Drill bit.
Sheldon
Re: Main dowel for "World" block, source? [Re: RUNCHARGER] #2566996
10/20/18 05:41 PM
10/20/18 05:41 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Originally Posted By RUNCHARGER
Drill bit.
It's a hollow cylinder shape. (It's not a pin).
Rich H.
Esse Quam Videri
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2566998
10/20/18 05:57 PM
10/20/18 05:57 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Check McMaster-Carr.
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2566999
10/20/18 06:01 PM
10/20/18 06:01 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Good idea, I will do McMaster again, my first shot was fruitless.
Was thinking it could possibly be pretty generic pioneer dowel or something like that.
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2567001
10/20/18 06:08 PM
10/20/18 06:08 PM
AndyF Online content
AndyF  Online Content
Can you post a picture. If you know the OD, ID and length I bet you can find it. I doubt that some engineer designed a custom dowel for that application but you never know. Some wizard at Chrysler designed different throttle cables and throttle springs year after year even though they didn't really need them.
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2567004
10/20/18 06:12 PM
10/20/18 06:12 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Got it. It's just a chunk of thin Wall tubing doctored up a bit.
I was looking in the wrong place. Thx for sending me back there fbs!
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2567488
10/21/18 09:42 PM
10/21/18 09:42 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2567489
10/21/18 09:53 PM
10/21/18 09:53 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thanks! If the tubing from mc master doesn't work, that's a backup.
Re: Main dowel for "World" block, source? [Re: AndyF] #2567574
10/22/18 12:16 AM
10/22/18 12:16 AM
Washington
madscientist Offline
Washington
Damn. Another AndyF post that made me LOL!
Quoted for truth for sure.
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2567789
10/22/18 12:50 PM
10/22/18 12:50 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
This type of activity still goes on today at the OEMs, there are still lots of jobs with almost comical narrow focus of responsibility.
Re: Main dowel for "World" block, source? [Re: The Shadow] #2567790
10/22/18 12:51 PM
10/22/18 12:51 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Originally Posted By The Shadow
Nope, now that I checked it..no workie....too big for the hole. Thank you for the idea, though. Would need to put it on a lathe, which is not out of the question.
Waiting for the mc master 5/8 thinwall tubing, as long as the od is within spec it should do the trick.
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2567997
10/22/18 08:21 PM
10/22/18 08:21 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Did you measure them?
They should be oversize
Unless the tube you get is slip fit it may be tough to install without damaging
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2568348
10/23/18 01:58 PM
10/23/18 01:58 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
The originals are a thin tube with a very light press fit.
Those would be .012" press fit which is too much.
I just have to hope the tube that shows up is in spec and not on the low side.
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2568647
10/23/18 11:22 PM
10/23/18 11:22 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
This will be super simple when I get a minute. Just needs maybe .001 polished off (optional, just to be same as the existing pieces), cut to length, bevel the ends, install.
Rich H.
Esse Quam Videri
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2568678
10/24/18 12:39 AM
10/24/18 12:39 AM
Make some extras and set up a service part number for them so you can find them in your garage 10 years from now when you need more!
Re: Main dowel for "World" block, source? [Re: ZIPPY] #2568882
10/24/18 02:02 PM
10/24/18 02:02 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Right, now that I've got enough to make a whole set, temptation is to replace them all for really no reason.
Rich H.
Esse Quam Videri
