Comp cams XE 284 cam #2559809
10/06/18 11:48 AM
10/06/18 11:48 AM
Easton, PA
68DART360 Offline OP
Easton, PA
Anyone running one of these in a small block? Thinking about sticking one in a 318 with edelbrock heads. Drag car only. 4.10 gear 8" ptc converter 904. reusing all of the stuff off my 11.0 360.
Re: Comp cams XE 284 cam [Re: 68DART360] #2559833
10/06/18 12:35 PM
10/06/18 12:35 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I have that cam in a BB 505 street car. It's got very nice street manners, idles nice at 850, still pulls good up to 6k. Probably doesn't help you any with your small block race question, but just thought I'd mention that I'm happy with mine. Actually planning on upgrading the heads and still keeping the cam.
2 kids and a dog
Re: Comp cams XE 284 cam [Re: TonyS451] #2563257
10/13/18 08:44 AM
10/13/18 08:44 AM
Easton, PA
Easton, PA
Thanks, anybody else?
Re: Comp cams XE 284 cam [Re: 68DART360] #2563312
10/13/18 11:38 AM
10/13/18 11:38 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
There’s really only way to know how it will work in your combo....... and that’s to try it.
You must have a reason you want to try that cam......and the way to learn what’s worth what is to try things and see if they work out according to the “plan”.
30+ years ago when I was figuring this stuff out and racing a lot, trying different parts on my car, trying to go faster......... I put 4 cams in my motor in one summer.
Re: Comp cams XE 284 cam [Re: 68DART360] #2563351
10/13/18 12:42 PM
10/13/18 12:42 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
FWIW, we run the XE268H cam in our .030 over 318, 10.5:1 with ported and 360 size valves in the 302 heads. We've ran 14.20 lifting with a 3.23 rear. TBH it's a bit doggy until it hits 3000. Also has an air gap rpm intake and 600 d/p Holley, car weighs around 3500lb full street trim. It should go 13's but we haven't done it yet.
Re: Comp cams XE 284 cam [Re: Tig] #2563998
10/14/18 06:45 PM
10/14/18 06:45 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
Use one on my 318. Best et so far 8.5 1.71 60" with some nos. For street is OK but for the strip I would prever some bigger mechanical flat tapped.
Br,
1973 Brasilian Dart
E100, boosted 390"
Re: Comp cams XE 284 cam [Re: 68DART360] #2564510
10/15/18 05:48 PM
10/15/18 05:48 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
I had one in my 340 for a while, ran and sounded good. Changing combos so its in the classifieds if you want to save a few bucks trying one out.
