Re: Comp cams XE 284 cam
[Re: 68DART360]
#2559833
10/06/18 12:35 PM
10/06/18 12:35 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
I have that cam in a BB 505 street car. It's got very nice street manners, idles nice at 850, still pulls good up to 6k. Probably doesn't help you any with your small block race question, but just thought I'd mention that I'm happy with mine. Actually planning on upgrading the heads and still keeping the cam.
2 kids and a dog
[Re: 68DART360]
#2563312
10/13/18 11:38 AM
10/13/18 11:38 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
There’s really only way to know how it will work in your combo....... and that’s to try it.
You must have a reason you want to try that cam......and the way to learn what’s worth what is to try things and see if they work out according to the “plan”.
30+ years ago when I was figuring this stuff out and racing a lot, trying different parts on my car, trying to go faster......... I put 4 cams in my motor in one summer.
[Re: 68DART360]
#2563351
10/13/18 12:42 PM
10/13/18 12:42 PM
Posts: 2,924 A shed in England
Tig
A shed in England
FWIW, we run the XE268H cam in our .030 over 318, 10.5:1 with ported and 360 size valves in the 302 heads. We've ran 14.20 lifting with a 3.23 rear. TBH it's a bit doggy until it hits 3000. Also has an air gap rpm intake and 600 d/p Holley, car weighs around 3500lb full street trim. It should go 13's but we haven't done it yet.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2563998
10/14/18 06:45 PM
10/14/18 06:45 PM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
Use one on my 318. Best et so far 8.5 1.71 60" with some nos. For street is OK but for the strip I would prever some bigger mechanical flat tapped.
Br,
1973 Brasilian Dart E100, boosted 390"
