3" Rear Exiting Exhaust and Rear Sway Bar Fit E-body?
#2555953
09/28/18 01:01 PM
09/28/18 01:01 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
I am thinking about adding a rear sway bar to my '70 Challenger. It looks like it will be awfully tight, I assume the bar would have to go between the exhaust and the body/frame. Has anyone added a rear bar with 3" (TTI) exhaust? Did you have to modify anything? I am looking at the Firm feel setup, as I like the factory style setup. http://www.firmfeel.com/e_body_mopar_rear_sway_bar.html Pics would be great.
Re: 3" Rear Exiting Exhaust and Rear Sway Bar Fit E-body?
[Re: 70BigBlockSE]
#2557662
10/02/18 02:17 PM
10/02/18 02:17 PM
challenger70
Berwyn, IL
I have both the FFI 3/4" rear bar and TTI 3" exhaust on my 70 Challenger. But I'm working in Mississippi and my car is back in Jacksonville. I'll dig for some pictures but it was a non-issue Awesome, thanks. I suppose even a little massaging of the exhaust wouldn't hurt too much that far back.
[Re: GoodysGotaCuda]
#2557692
10/02/18 02:55 PM
10/02/18 02:55 PM
challenger70
Berwyn, IL
I have no problem with TTI 3" and a Hotchkis sway bar. I think the Hotchkis hangs below the axle so it wouldn't have the same issue as a factory style setup, where you have the exhaust up and over the axle and the sway bar in that area too. The T/A exhaust makes a lot more sense now.
[Re: challenger70]
#2557765
10/02/18 04:57 PM
10/02/18 04:57 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Hi Ron,
The T/A exhaust was only for appearance and cosmetics to replicate side exhaust (really was not a good factory design performance wise)... there were other factory model e-bodies that had the rear sway bar with the factory rear exhaust over the differential... however, those were smaller diameter exhaust tubes (~2.5"?)
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: challenger70]
#2558056
10/03/18 12:49 AM
10/03/18 12:49 AM
Posts: 200 Colorado
Bob J
Colorado
I think that the pipes that went over the axle were 2 1/4" but 2 1/5 before the muffler.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
