3" Rear Exiting Exhaust and Rear Sway Bar Fit E-body? #2555953
09/28/18 01:01 PM
09/28/18 01:01 PM
Berwyn, IL
challenger70 Offline OP
Berwyn, IL
I am thinking about adding a rear sway bar to my '70 Challenger. It looks like it will be awfully tight, I assume the bar would have to go between the exhaust and the body/frame.
Has anyone added a rear bar with 3" (TTI) exhaust? Did you have to modify anything?
I am looking at the Firm feel setup, as I like the factory style setup. http://www.firmfeel.com/e_body_mopar_rear_sway_bar.html Pics would be great.
Re: 3" Rear Exiting Exhaust and Rear Sway Bar Fit E-body? [Re: challenger70] #2555977
09/28/18 01:59 PM
09/28/18 01:59 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
If you go on the TTI site there are footnotes that have pics showing what swaybars their stuff works with. Here is the direct link
http://www.ttiexhaust.com/Footnotes/FN_18.htm
http://www.ttiexhaust.com/MoparClassics-Exhaust/Exhaust_Syst_HW.htm
note says it won't work with the Firm Feel
Re: 3" Rear Exiting Exhaust and Rear Sway Bar Fit E-body? [Re: gzig5] #2555983
09/28/18 02:06 PM
09/28/18 02:06 PM
Berwyn, IL
Berwyn, IL
Seems contradictory to me, is not the Firm feel setup almost identical to the factory setup?
"TTi tailpipes will clear the factory rear sway bars or equivalent style aftermarket designs."
(!) Tailpipes will not clear aftermarket sway bars that are mounted above and forward of the rear axle."
"Tailpipe will not clear the FFI swaybar."
Re: 3" Rear Exiting Exhaust and Rear Sway Bar Fit E-body? [Re: challenger70] #2556330
09/29/18 05:44 PM
09/29/18 05:44 PM
Jacksonville Fl
70BigBlockSE Offline
Jacksonville Fl
I have both the FFI 3/4" rear bar and TTI 3" exhaust on my 70 Challenger. But I'm working in Mississippi and my car is back in Jacksonville. I'll dig for some pictures but it was a non-issue
Re: 3" Rear Exiting Exhaust and Rear Sway Bar Fit E-body? [Re: challenger70] #2556384
09/29/18 08:31 PM
09/29/18 08:31 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have no problem with TTI 3" and a Hotchkis sway bar.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 3" Rear Exiting Exhaust and Rear Sway Bar Fit E-body? [Re: 70BigBlockSE] #2557662
10/02/18 02:17 PM
10/02/18 02:17 PM
Berwyn, IL
Berwyn, IL
Awesome, thanks. I suppose even a little massaging of the exhaust wouldn't hurt too much that far back.
Re: 3" Rear Exiting Exhaust and Rear Sway Bar Fit E-body? [Re: GoodysGotaCuda] #2557692
10/02/18 02:55 PM
10/02/18 02:55 PM
Berwyn, IL
Berwyn, IL
I think the Hotchkis hangs below the axle so it wouldn't have the same issue as a factory style setup, where you have the exhaust up and over the axle and the sway bar in that area too. The T/A exhaust makes a lot more sense now.
Re: 3" Rear Exiting Exhaust and Rear Sway Bar Fit E-body? [Re: challenger70] #2557765
10/02/18 04:57 PM
10/02/18 04:57 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Hi Ron,
The T/A exhaust was only for appearance and cosmetics to replicate side exhaust (really was not a good factory design performance wise)... there were other factory model e-bodies that had the rear sway bar with the factory rear exhaust over the differential... however, those were smaller diameter exhaust tubes (~2.5"?)
Re: 3" Rear Exiting Exhaust and Rear Sway Bar Fit E-body? [Re: challenger70] #2558056
10/03/18 12:49 AM
10/03/18 12:49 AM
Colorado
Bob J Offline
Bob J  Offline
Colorado
I think that the pipes that went over the axle were 2 1/4" but 2 1/5 before the muffler.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: 3" Rear Exiting Exhaust and Rear Sway Bar Fit E-body? [Re: challenger70] #2559932
10/06/18 04:35 PM
10/06/18 04:35 PM
Portland, OR
shawge Offline
shawge  Offline
Portland, OR
No issues w/ 3" TTI pipes and FF rear sway bar on a 70 Challenger. I have ~2" of room at the tightest spots.
