Leaking oil past oil filter gasket #2555208
09/26/18 09:11 PM
09/26/18 09:11 PM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
I have an edelbrock headed 340. When the car sits for a while it will spew oil past the rubber gasket on the oil filter. What is the cause and what is the cure?
thx Diego
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2555210
09/26/18 09:16 PM
09/26/18 09:16 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Did you check to see if the last filter came free & left its gasket on the block?
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2555213
09/26/18 09:20 PM
09/26/18 09:20 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
got an oil pressure gauge on it? Put one one and look at the pressure when this happens. Might be an oil pressure relief valve getting sticky but without a gauge we're all guessing.
Don't be the exception.
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2555219
09/26/18 09:35 PM
09/26/18 09:35 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Schlitz King Can
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2555232
09/26/18 09:58 PM
09/26/18 09:58 PM
Diego-Town, CA
Diego-Town, CA
No left over gasket. Oil pressure around 60 psi at start up. Does not always happen, just now the then?
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2555237
09/26/18 10:08 PM
09/26/18 10:08 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Easy & cheap to replace the filter & see what happens.
Once the old one is off, you can check for issues with it & the gasket mating surface.
Possibly multiple 'surfaces' if it has the 90 degree adapter?
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2555287
09/26/18 11:13 PM
09/26/18 11:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
60 psi should not be a problem.
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2555293
09/26/18 11:23 PM
09/26/18 11:23 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Maybe its leaking from the gasket from between the screw on oil filter adapter plate and the block?
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2555393
09/27/18 04:32 AM
09/27/18 04:32 AM
Is it mounted on a ninety degree adapter or straight into the side of the block?
Its weird that is does it now and then instead of all the time work confused
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2555456
09/27/18 11:14 AM
09/27/18 11:14 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Does it only happen on the most recent oil filter, or has it done the same thing with previous oil filters?
Is it really a "spew" or more of a "seep" when it sits?
As mentioned, maybe a defect on the mating surface? If it were me I would start by pulling the filter and inspecting the mating surface for defects/flatness. Although those rubber gaskets are pretty forgiving...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2555480
09/27/18 11:50 AM
09/27/18 11:50 AM
Diego-Town, CA
Diego-Town, CA
It has always done it. It is a spew about 1/2 a cups worth. It's got a 90* adapter. All mating surface seem good. Yes only now and then but mostly after has been sitting for more than a few days or weeks? The leak is not from the adapter to block junction.
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2555516
09/27/18 01:17 PM
09/27/18 01:17 PM
moparx Offline
moparx  Offline
have you tried to re-tighten the filter [by hand] when this happens ? as mentioned, possibly a mating surface problem that does not allow the filter to fully seat after a few heat cycles. worth a try anyway.
beer
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2555854
09/28/18 08:01 AM
09/28/18 08:01 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Didn’t realize you were back from the dead Ted!! Blast from the past right here... guess I only check the racing section 99% of the time.
Have you tried different filters? Thinking I’d throw a Mopar on there and see what happens
Re: Leaking oil past oil filter gasket [Re: J_BODY] #2555967
09/28/18 01:40 PM
09/28/18 01:40 PM
Diego-Town, CA
Diego-Town, CA
J Bod, good to hear from you, been a long long time! Yes I am coming back hope to retire next year and be a presence back on Moparts!! How have you been, good I hope.
Diego
Re: Leaking oil past oil filter gasket [Re: Diego_Ted] #2556343
09/29/18 06:41 PM
09/29/18 06:41 PM
either the filter mounting gasket is leaking (get a new filter, not a Fram) or the thin gasket under the big mounting bolt head is leaking in which case get the 3 piece gasket set from MP & undo everything/clean/reinstall.
