Re: Leaking oil past oil filter gasket
[Re: Diego_Ted]
#2555213
09/26/18 09:20 PM
09/26/18 09:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
got an oil pressure gauge on it? Put one one and look at the pressure when this happens. Might be an oil pressure relief valve getting sticky but without a gauge we're all guessing.
[Re: Diego_Ted]
#2555287
09/26/18 11:13 PM
09/26/18 11:13 PM
Supercuda
About to go away
About to go away
up yours
60 psi should not be a problem.
[Re: Diego_Ted]
#2555456
09/27/18 11:14 AM
09/27/18 11:14 AM
Posts: 3,374 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Does it only happen on the most recent oil filter, or has it done the same thing with previous oil filters?
Is it really a "spew" or more of a "seep" when it sits?
As mentioned, maybe a defect on the mating surface? If it were me I would start by pulling the filter and inspecting the mating surface for defects/flatness. Although those rubber gaskets are pretty forgiving...
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: Diego_Ted]
#2556343
09/29/18 06:41 PM
09/29/18 06:41 PM
RapidRobert
either the filter mounting gasket is leaking (get a new filter, not a Fram) or the thin gasket under the big mounting bolt head is leaking in which case get the 3 piece gasket set from MP & undo everything/clean/reinstall.
