Re: What cam would I have used in the 70's
[Re: charge70]
#2548777
09/11/18 01:59 PM
09/11/18 01:59 PM
Posts: 5,345 Planet Earth
RoadRunnerLuva
Planet Earth
Direct Connection Purple Shaft .509 lift 292 duration Hydralic cam. Oh, and don't forget the Holley #3310 750 cfm, Edelbrock dual plane, and some Hooker Headers attached to a pair of Thrush mufflers. All while listening to your Radio Shack 8 track player, with some KISS or maybe a little Foghat...
Plymouth Makes It!
[Re: lostdog]
#2548783
09/11/18 02:05 PM
09/11/18 02:05 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
Isky 1012B was popular at the beginning of the '70s. The 1012C was another one I heard about a few times.
Rich H.
Esse Quam Videri
[Re: lostdog]
#2548797
09/11/18 02:33 PM
09/11/18 02:33 PM
ZIPPY
S.E. Michigan
You're definitely well on your way.
Those look like 346 head castings from the "II"....
Don't forget the Mallory Rev Pol, Voltmaster coil, paint the headers white, etc etc. Or maybe Accel dual point + super coil + yellow plug wires that always seem to be covered with grease stains. Definitely consider using solid core plug wires to cause as much radio interferance as possible. That's how they did it back then....
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2548800
09/11/18 02:38 PM
09/11/18 02:38 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
Zippy nail it OP, that old intake may make you change your mind on using after driving it a while I have one of them on a new small (464C.I.) stroker (3.91 stroke) pump gas motor 440 motor now with a 850 DP, I'm anxious to see how it works
[Re: AndyF]
#2548805
09/11/18 02:50 PM
09/11/18 02:50 PM
RoadRunnerLuva
Planet Earth
But the .509 cam with a Holley 3310 vac. sec.Edelbrock CH4B//727 w/3000 stall convertor/3.91 8-3/4 is the way to go. I used that combo back in the day in my factory stock headed 440 C Body, and it ran low 14:20's @99.5 MPH, in a 4600 lb. convertible...on street tires with full exhaust as well.
Plymouth Makes It!
[Re: ZIPPY]
#2548836
09/11/18 03:48 PM
09/11/18 03:48 PM
Posts: 361 mississippi
lostdog
mississippi
Yep these are the hipo 346 heads ! I have actually been considering using some of those other components you mention that are available to me
[Re: RoadRunnerLuva]
#2548851
09/11/18 04:12 PM
09/11/18 04:12 PM
lostdog
mississippi
But the .509 cam with a Holley 3310 vac. sec.Edelbrock CH4B//727 w/3000 stall convertor/3.91 8-3/4 is the way to go. I used that combo back in the day in my factory stock headed 440 C Body, and it ran low 14:20's @99.5 MPH, in a 4600 lb. convertible...on street tires with full exhaust as well. The 509 is definitely an option !
#2548853
09/11/18 04:14 PM
09/11/18 04:14 PM
lostdog
mississippi
Direct Connection Purple Shaft .509 lift 292 duration Hydralic cam. Oh, and don't forget the Holley #3310 750 cfm, Edelbrock dual plane, and some Hooker Headers attached to a pair of Thrush mufflers. All while listening to your Radio Shack 8 track player, with some KISS or maybe a little Foghat... Absolutely! Just like that Kiss Alive II !
[Re: AndyF]
#2548857
09/11/18 04:21 PM
09/11/18 04:21 PM
lostdog
mississippi
Use the 509 so it runs like crap with that carb. Then you'll get sick of driving it and park in the shed where it will become a barn find in 30 years. I think the 509 cam created the barn find Mopars since the engines ran so poorly with them. The 509 + 850 DP combo turned lots of nice 440 engines into stinky, plug eating piles back in the 70's. It was a barn (field) find when I got it ! Lol
[Re: lostdog]
#2548925
09/11/18 06:40 PM
09/11/18 06:40 PM
Cab_Burge
Do you want to run a hydraulic flat tappet, solid flat tappet or which type cam and lifters? I would stay away form some of the older cam grinds, especially the Mopar Purple shaft JUNK I see so many people on here advocating them(they have always, until recently, been cheaper in costs than any other brands out there and I wonder if those people have ran anything else I sold a friend a Mopar Purple Shaft 284 street hemi grind for a 383 motor going into a 1968 Charger with power brakes, he owned a automotive garage and it was for one of his bigger commercial customers Son car. I help him degree it, it had right at 4.5 inches of vacuum idling at 850 RPM in gear, enough to stop once good in traffic and not again in traffic very well He ended up buying a R.V. cam kit and installed himself straight up dot to dot The kid ended up wrapping that car around a power pole within the year of the motor work Take your time on the cam selection and make sure and degree it regardless of which brand or grind you choose
