Page 1 of 3 1 2 3
What cam would I have used in the 70's #2548772
09/11/18 01:53 PM
09/11/18 01:53 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I were going to "soup up" my B engine back in the 70's what cam would I have used ?
Re: What cam would I have used in the 70's [Re: lostdog] #2548774
09/11/18 01:56 PM
09/11/18 01:56 PM
Mass
charge70 Offline
charge70  Offline
Mass
Crane Fireball.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: What cam would I have used in the 70's [Re: charge70] #2548777
09/11/18 01:59 PM
09/11/18 01:59 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
Direct Connection Purple Shaft .509 lift 292 duration Hydralic cam.
Oh, and don't forget the Holley #3310 750 cfm, Edelbrock dual plane, and some Hooker Headers attached to a pair of Thrush mufflers. up
All while listening to your Radio Shack 8 track player, with some
KISS or maybe a little Foghat... work
Plymouth Makes It!
Re: What cam would I have used in the 70's [Re: lostdog] #2548780
09/11/18 02:02 PM
09/11/18 02:02 PM
P
Porter67 Offline
Porter67  Offline
P
You question is a bit vague. Some will say a purple shaft.
I like old vintage cams, big and stinky but some dont.
There are from time to time some good old vintage cams on ebay, her is a current one for a BB and it almost looks to me like you could use a new oem spring or still a single, but im not a BB or cam expert but here is the link.
Pretty mild but above stock it seems.
https://www.ebay.com/itm/Big-Block-Chrysler-Dodge-MOPAR-V8-Speed-Pro-CS-181R-Performance-Camshaft-Cam/182798760006?epid=23009291102&hash=item2a8fa7b846:g:LkQAAOSwXedZz6jF
You should probably post the combo you have now and what your expectations are.
Re: What cam would I have used in the 70's [Re: lostdog] #2548783
09/11/18 02:05 PM
09/11/18 02:05 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Isky 1012B was popular at the beginning of the '70s.
The 1012C was another one I heard about a few times.
Rich H.
Esse Quam Videri
Re: What cam would I have used in the 70's [Re: Porter67] #2548785
09/11/18 02:07 PM
09/11/18 02:07 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Using a vintage Weiand intake and cal custom valve covers on the B engine (400) I’m putting in my ‘73 Barracuda. Thinking of keeping Old school cam too. I’m not racing so it’s not particularly important that my combo isn’t awesome.
Re: What cam would I have used in the 70's [Re: lostdog] #2548797
09/11/18 02:33 PM
09/11/18 02:33 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
You're definitely well on your way.
Those look like 346 head castings from the "II"....
Don't forget the Mallory Rev Pol, Voltmaster coil, paint the headers white, etc etc. Or maybe Accel dual point + super coil + yellow plug wires that always seem to be covered with grease stains. Definitely consider using solid core plug wires to cause as much radio interferance as possible. That's how they did it back then....
Rich H.
Esse Quam Videri
Re: What cam would I have used in the 70's [Re: ZIPPY] #2548799
09/11/18 02:36 PM
09/11/18 02:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
from the '70 Hustle Stuff catalog * RACER BROWN SSH-25
http://www.4secondsflat.com/RB%20Cam%20Specs.htm
D-C hustle stuff 1970 catalog.jpgmoparts hustle stuff BEE-LIEVER respiratory system.jpg
Re: What cam would I have used in the 70's [Re: ZIPPY] #2548800
09/11/18 02:38 PM
09/11/18 02:38 PM
Zippy nail it boogie up
OP, that old intake may make you change your mind on using after driving it a while shruggy work
I have one of them on a new small (464C.I.) stroker (3.91 stroke) pump gas motor 440 motor now with a 850 DP, I'm anxious to see how it works luck
Re: What cam would I have used in the 70's [Re: lostdog] #2548801
09/11/18 02:42 PM
09/11/18 02:42 PM
AndyF Offline
AndyF  Offline
Use the 509 so it runs like crap with that carb. Then you'll get sick of driving it and park in the shed where it will become a barn find in 30 years. I think the 509 cam created the barn find Mopars since the engines ran so poorly with them. The 509 + 850 DP combo turned lots of nice 440 engines into stinky, plug eating piles back in the 70's.
Re: What cam would I have used in the 70's [Re: AndyF] #2548805
09/11/18 02:50 PM
09/11/18 02:50 PM
Planet Earth
Planet Earth
But the .509 cam with a Holley 3310 vac. sec.Edelbrock CH4B//727 w/3000 stall convertor/3.91 8-3/4 is the way to go. up
I used that combo back in the day in my factory stock headed 440 C Body, and it ran low 14:20's @99.5 MPH, in a 4600 lb. convertible...on street tires with full exhaust as well.
Plymouth Makes It!
Re: What cam would I have used in the 70's [Re: ZIPPY] #2548836
09/11/18 03:48 PM
09/11/18 03:48 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Yep these are the hipo 346 heads ! I have actually been considering using some of those other components you mention that are available to me
Re: What cam would I have used in the 70's [Re: 6bblgt] #2548838
09/11/18 03:50 PM
09/11/18 03:50 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
That's cool!
Re: What cam would I have used in the 70's [Re: Cab_Burge] #2548849
09/11/18 04:11 PM
09/11/18 04:11 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I have no idea what this intake will do. The reason I got the 400 is for future stroker build. But that’s not a priority right now and since this engine I got is running in decent shape I’m going to run it. I’m the carb I have is a 700 annular discharge.
Re: What cam would I have used in the 70's [Re: RoadRunnerLuva] #2548851
09/11/18 04:12 PM
09/11/18 04:12 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
The 509 is definitely an option !
Re: What cam would I have used in the 70's [Re: RoadRunnerLuva] #2548853
09/11/18 04:14 PM
09/11/18 04:14 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Absolutely! Just like that Kiss Alive II !
Re: What cam would I have used in the 70's [Re: AndyF] #2548857
09/11/18 04:21 PM
09/11/18 04:21 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
It was a barn (field) find when I got it ! Lol
29ADF428-5B0A-400F-A725-DBD2553CF5A5.jpegAD76F10C-2A4F-4579-8F2E-500123DDC9EE.jpeg2937E4C1-CCB1-4945-A1AB-E52F85A62311.jpeg35121D35-1E8D-4DC7-BBD8-E480239C297F.jpeg
Re: What cam would I have used in the 70's [Re: lostdog] #2548874
09/11/18 05:08 PM
09/11/18 05:08 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
your safest bet is the old street hemi grind.
Re: What cam would I have used in the 70's [Re: lostdog] #2548925
09/11/18 06:40 PM
09/11/18 06:40 PM
Do you want to run a hydraulic flat tappet, solid flat tappet or which type cam and lifters?
I would stay away form some of the older cam grinds, especially the Mopar Purple shaft JUNK tsk twocents
I see so many people on here advocating them(they have always, until recently, been cheaper in costs than any other brands out there and I wonder if those people have ran anything else shruggy
I sold a friend a Mopar Purple Shaft 284 street hemi grind for a 383 motor going into a 1968 Charger with power brakes, he owned a automotive garage and it was for one of his bigger commercial customers Son car. I help him degree it, it had right at 4.5 inches of vacuum idling at 850 RPM in gear, enough to stop once good in traffic and not again in traffic very well tsk
He ended up buying a R.V. cam kit and installed himself straight up dot to dot whiney
The kid ended up wrapping that car around a power pole within the year of the motor work shruggy
Take your time on the cam selection and make sure and degree it regardless of which brand or grind you choose up scope twocents
Re: What cam would I have used in the 70's [Re: Cab_Burge] #2548927
09/11/18 06:46 PM
09/11/18 06:46 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
That's strange... must have been something else wrong since you degreed it for him. Huge vacuum leak maybe? I put that exact same Purple Shaft cam (284/.484) in my basically stock 383 rebuild. It idled with a very minor lope at 13" vacuum at 750 rpm! shruggy
Page 1 of 3 1 2 3
