Re: Torsion Bars
[Re: scarly10]
#2548832
09/11/18 03:44 PM
09/11/18 03:44 PM
Posts: 11,562 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Mopar A-Body Torsion Bar Size and Part Number Reference Torsion Bar Diameter Spring Rate Mopar Performance# OEM # Application .810″ 90 lb/in p5249148 drag bars .830″ 100 lb/in 2535888 2535889 slant six bars .850″ 110 lb/in 2535890 2535891 slant six/318 .870″ 120 lb/in p5249149 2535892 2535893 318 w/air/340 .890″ 130 lb/in p5249150 2535894 2535895 383 standard .920″ 150 lb/in p5249151 heavy duty handling .990″ 200 lb/in p5249152 solo/road race 1.040″ 250 lb/in p5249153 heavy duty road race-oval track 1.090″ 300 lb/in p5249154 oval track 1/4 mi–opt.1/2 mi 1.140″ 300 lb/in p5249155 oval track 1/4 and 1/2 mil
.810. Use a good DA shock to control it.
Re: Torsion Bars
[Re: 70satelliteguy]
#2548902
09/11/18 05:52 PM
09/11/18 05:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've never seen a bent bar.. unless put a torch to it.. seen plenty of broke ones and broke a few when I was making F-body bars back in the day
Re: Torsion Bars
[Re: scarly10]
#2548935
09/11/18 07:08 PM
09/11/18 07:08 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Like any spring, a torsion bar is subject to going soft or loosing its original dimension if over stressed and/or worked repeatedly like a light rate spring that's compressed to store energy.
