"The Block" Dyno Results #2546973
09/06/18 11:28 PM
09/06/18 11:28 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
So my motor hit the dyno yesterday. You might have seen some of the other posts I had about the engine.
It is the aftermarket "The Block" RB 505 CI. It had some issues that needed to get corrected so I decided to have Tony Bischoff Fix it and assemble it all the way to the dyno session. I can't say enough about Tony and his team - absolutely top notch!
The motor ran very well on the dyno.
Basic specs:
new aftermarket "The Block"
505 CI
Molnar crank & rods - 4.25 inch stroke
OOTB TrickFlow 270 heads
Mopar Performance 337 intake
4150 carb - flows 1000 cfm
solid roller cam around 650 lift - smaller duration (Dwayne Porter spec'd)
10.9:1 compression
93 pump gas
Hooker 5209 2 inch headers
Made 713 hp @ 6000 rpm and 707 ft/lbs torque at 4600 rpm. I did not expect that much torque - it makes the same torque as my race car motor!
Need to thank Dwayne Porter for the great job on picking the cam and all the other guidance he provided for the build.
I am very happy with the results..........
Re: "The Block" Dyno Results [Re: markz528] #2547042
09/07/18 02:01 AM
09/07/18 02:01 AM
AndyF Offline
AndyF  Offline
Sounds like a good one. This is going into your street car? A buddy of mine is doing a 505 this fall with the 270 heads. We figure it will make around 700 hp but I'm not expecting 700 ft lbs of torque!
Re: "The Block" Dyno Results [Re: markz528] #2547054
09/07/18 03:24 AM
09/07/18 03:24 AM
WI
mopar873 Offline
mopar873  Offline
WI
Very nice numbers, that will be an absolute monster on the street.
Re: "The Block" Dyno Results [Re: markz528] #2547060
09/07/18 03:55 AM
09/07/18 03:55 AM
It seems like the Mopar BB pump gas motors with less than 10.5 to 1 compression ratio make more torque than HP, above that they make more HP than torque confused shruggy
Why, I do not know confused work
Re: "The Block" Dyno Results [Re: markz528] #2547063
09/07/18 04:32 AM
09/07/18 04:32 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Very impressive, congratulations!
Re: "The Block" Dyno Results [Re: markz528] #2547067
09/07/18 05:25 AM
09/07/18 05:25 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Nice result
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: "The Block" Dyno Results [Re: tex013] #2547070
09/07/18 07:10 AM
09/07/18 07:10 AM
birdtracker Offline
birdtracker  Offline
Congrats. Hope you get it in the car and can enjoy it alittle this year still. Birdtracker
Re: "The Block" Dyno Results [Re: markz528] #2547080
09/07/18 09:29 AM
09/07/18 09:29 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Sounds like a really nice combo. Now get taping!
Re: "The Block" Dyno Results [Re: markz528] #2547097
09/07/18 10:49 AM
09/07/18 10:49 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Very nice results!!!
Re: "The Block" Dyno Results [Re: markz528] #2547113
09/07/18 11:21 AM
09/07/18 11:21 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Thanks Mark...... I enjoyed being a part of the build.
Glad you got it sorted out....... and now we’ll be waiting for the future “the Block - track results” thread.😎
Re: "The Block" Dyno Results [Re: markz528] #2547116
09/07/18 11:28 AM
09/07/18 11:28 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Wow...
What's the rest of the car's combination for gearing, trans type, converter (if auto), differential, rollbar, frame connectors, etc.?
If this engine is going into the 13-sec car in your signature, you're going to find out very quickly where the weak links in the drive train are w/ all that torque.
Oh, do you have a performance goal, other than to see how quickly you can wear your rear tires down to the cords? grin
Re: "The Block" Dyno Results [Re: markz528] #2548279
09/10/18 10:40 AM
09/10/18 10:40 AM
an8sec70cuda Offline
Very nice, impressive!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: "The Block" Dyno Results [Re: BradH] #2548336
09/10/18 12:30 PM
09/10/18 12:30 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Originally Posted By BradH
Wow...
Nope - its for my GTX build. It will be heavy. It has a full interior. I expect 3800 - 3900 lbs. Goal is 10.30's on the track and some street time.
Its got a John Holt chassis. Frame connectors, full chrome moly cage (he talked me into the full cage), Cal Tracs, mini tub, etc. Its got P315/60R-15 tires (30 inch tall) for the street and lots of room to go bigger.
Its got too much gear. I put 4.56 gear in it and it should be 4.30 or maybe even 4.10. Its a new S60 that John built. Gear ratio might get changed. But it does have a good Jeff Russell prepped 727 with a A&A brake and steel drum and a Gear Vendors overdrive that drops the gear ratio to 3.55. Its my backup race car tranny. The converter is a Dynamic 9.5 inch and is heading to them this week for redo to match the car.
Re: "The Block" Dyno Results [Re: markz528] #2548372
09/10/18 01:43 PM
09/10/18 01:43 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Wow good luck with your build can't wait to see it all finished up I'm close to Holt's place let us know when you're taking the car out
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: "The Block" Dyno Results [Re: markz528] #2548815
09/11/18 03:09 PM
09/11/18 03:09 PM
wi
Furys Offline
Furys  Offline
wi
Where can I get one of those blocks?or any rb aftermarket race block even an aluminum one
Re: "The Block" Dyno Results [Re: Furys] #2548875
09/11/18 05:09 PM
09/11/18 05:09 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Bill @ Chicago Connection is trying very hard. There is good hope that they will be readily available. When I talked with him last week he was swamped and needed to make some calls to get the latest updates.
Call Bill @ Chicago Connection and ask him.
Re: "The Block" Dyno Results [Re: markz528] #2549038
09/11/18 11:23 PM
09/11/18 11:23 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Congrats on that nice killer pump gas eng. She is gonna run good. up Ron
Re: "The Block" Dyno Results [Re: markz528] #2549054
09/11/18 11:48 PM
09/11/18 11:48 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That will be a fun motor!
