"The Block" Dyno Results
#2546973
09/06/18 11:28 PM
09/06/18 11:28 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
So my motor hit the dyno yesterday. You might have seen some of the other posts I had about the engine.
It is the aftermarket "The Block" RB 505 CI. It had some issues that needed to get corrected so I decided to have Tony Bischoff Fix it and assemble it all the way to the dyno session. I can't say enough about Tony and his team - absolutely top notch!
The motor ran very well on the dyno.
Basic specs:
new aftermarket "The Block" 505 CI Molnar crank & rods - 4.25 inch stroke OOTB TrickFlow 270 heads Mopar Performance 337 intake 4150 carb - flows 1000 cfm solid roller cam around 650 lift - smaller duration (Dwayne Porter spec'd) 10.9:1 compression 93 pump gas Hooker 5209 2 inch headers
Made 713 hp @ 6000 rpm and 707 ft/lbs torque at 4600 rpm. I did not expect that much torque - it makes the same torque as my race car motor!
Need to thank Dwayne Porter for the great job on picking the cam and all the other guidance he provided for the build.
I am very happy with the results..........
Re: "The Block" Dyno Results
[Re: markz528]
#2547113
09/07/18 11:21 AM
09/07/18 11:21 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Need to thank Dwayne Porter for the great job on picking the cam and all the other guidance he provided for the build. Thanks Mark...... I enjoyed being a part of the build. Glad you got it sorted out....... and now we’ll be waiting for the future “the Block - track results” thread.😎
[Re: markz528]
#2547116
09/07/18 11:28 AM
09/07/18 11:28 AM
BradH
Wow... What's the rest of the car's combination for gearing, trans type, converter (if auto), differential, rollbar, frame connectors, etc.? If this engine is going into the 13-sec car in your signature, you're going to find out very quickly where the weak links in the drive train are w/ all that torque. Oh, do you have a performance goal, other than to see how quickly you can wear your rear tires down to the cords?
[Re: markz528]
#2548279
09/10/18 10:40 AM
09/10/18 10:40 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
[Re: BradH]
#2548336
09/10/18 12:30 PM
09/10/18 12:30 PM
markz528
Morrow, OH
Wow... What's the rest of the car's combination for gearing, trans type, converter (if auto), differential, rollbar, frame connectors, etc.? If this engine is going into the 13-sec car in your signature, you're going to find out very quickly where the weak links in the drive train are w/ all that torque. Oh, do you have a performance goal, other than to see how quickly you can wear your rear tires down to the cords? Nope - its for my GTX build. It will be heavy. It has a full interior. I expect 3800 - 3900 lbs. Goal is 10.30's on the track and some street time. Its got a John Holt chassis. Frame connectors, full chrome moly cage (he talked me into the full cage), Cal Tracs, mini tub, etc. Its got P315/60R-15 tires (30 inch tall) for the street and lots of room to go bigger. Its got too much gear. I put 4.56 gear in it and it should be 4.30 or maybe even 4.10. Its a new S60 that John built. Gear ratio might get changed. But it does have a good Jeff Russell prepped 727 with a A&A brake and steel drum and a Gear Vendors overdrive that drops the gear ratio to 3.55. Its my backup race car tranny. The converter is a Dynamic 9.5 inch and is heading to them this week for redo to match the car.
[Re: markz528]
#2548372
09/10/18 01:43 PM
09/10/18 01:43 PM
Posts: 1,030 ohio
67mprfan
ohio
Wow good luck with your build can't wait to see it all finished up I'm close to Holt's place let us know when you're taking the car out
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: Furys]
#2548875
09/11/18 05:09 PM
09/11/18 05:09 PM
markz528
Morrow, OH
Where can I get one of those blocks?or any rb aftermarket race block even an aluminum one Bill @ Chicago Connection is trying very hard. There is good hope that they will be readily available. When I talked with him last week he was swamped and needed to make some calls to get the latest updates. Call Bill @ Chicago Connection and ask him.
[Re: markz528]
#2549054
09/11/18 11:48 PM
09/11/18 11:48 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
That will be a fun motor!
