Recommend a pan for 727? #2543999
08/31/18 09:49 PM
08/31/18 09:49 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Can anyone recommend a good trans pan for 727 with a drain plug? I would love to find a cast one, but can't find anything that isn't deeper, and I don't want it hanging any lower.
I bought a thick steel, can't remember the brand, years ago, but put it in storage shortly after. I've had leak problems ever since, and yes it'sthe pan. It's 3/16" and nearly impossible for me to get it flat. I've tried all the gaskets including the reusable 46re.
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Recommend a pan for 727? [Re: closer9] #2544018
08/31/18 10:41 PM
08/31/18 10:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
5 options at Summitt, none cast because of the stock depth requirement.
https://tinyurl.com/y7ck5yeg
I've used none of them, seems they don't carry the one I used in the past anymore.
Don't be the exception.
Re: Recommend a pan for 727? [Re: closer9] #2544023
08/31/18 11:00 PM
08/31/18 11:00 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
I looked at Summit and read all the reviews. Just curious if there was anything else or if anyone had used them.
TCI steel pan seems to have the best reviews. I did see they make a +2 quart aluminum that got good reviews, but still adds 2".
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Recommend a pan for 727? [Re: closer9] #2544027
08/31/18 11:09 PM
08/31/18 11:09 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Hmmm... hadn't seen/tried the steel core Moroso gasket. Been reading up on it. Might try it before I give up on this pan.
https://www.summitracing.com/parts/mor-93110
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Recommend a pan for 727? [Re: closer9] #2544032
08/31/18 11:16 PM
08/31/18 11:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I used the MP steel pan and the steel core pan gasket on my 64 300's 727. No issues, once I helicoiled all the stripped out pan bolt holes. I don't know if you eliminated other possibilities for the source of the leak, but there are a number of other areas than can leak and make you think it's the pan. The trickiest one to recognize is the kickdown/shifter shaft seal.
You might consider the 46RE pan, rockauto has them with plug for a reasonable cost, 98 1500 360 V8
Re: Recommend a pan for 727? [Re: closer9] #2544038
08/31/18 11:26 PM
08/31/18 11:26 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Yeah, I've replaced all the seals. It's dry above the gasket. This last time I thought I had it fixed, I just let it idle in neutral to keep leaks from getting blown around.
I'm currently using the 46RE gasket. The rubber strips are very thin.
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Recommend a pan for 727? [Re: closer9] #2544126
09/01/18 03:22 AM
09/01/18 03:22 AM
No way to beat/persuade it flat I am assuming.
Re: Recommend a pan for 727? [Re: closer9] #2544136
09/01/18 05:27 AM
09/01/18 05:27 AM
Guitar Jones Online laugh2
The rear band lever pivot shaft is a source of many so called pan leaks. If it's wet at the rear of the pan rail this could be your issue.
Re: Recommend a pan for 727? [Re: closer9] #2544225
09/01/18 12:52 PM
09/01/18 12:52 PM
md
mopars4ever Offline
mopars4ever  Offline
md
You may have already done so but make sure there is no sealer is in any of the bolt holes. I had a couple bottom out before getting tight because of silicone in the holes. Also the Right Stuff sealant will seal about anything but it makes for tough removal later.
https://www.permatex.com/our-brands/the-right-stuff/
Re: Recommend a pan for 727? [Re: closer9] #2544281
09/01/18 02:52 PM
09/01/18 02:52 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
Yeah. I did the rear band shaft a few years back, but now feeling kinda stupid. I don't think I've bothered to check if the screws are bottoming out. I think I may get the Morroso gasket and will try it and make sure all the holes are cleaned out. Might go ahead and get the TCI stamped pan while I'm at it.
Thanks, guys.
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Recommend a pan for 727? [Re: closer9] #2544285
09/01/18 03:08 PM
09/01/18 03:08 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I put this MP pan on. Has extra capacity but not so much that it hangs too low. Comes with everything you need including a nice gasket and extra length bolts. It's already paid for itself allowing me to drain the trans in a controlled manner a couple times.
https://www.summitracing.com/parts/dcc-3690730/overview/
Re: Recommend a pan for 727? [Re: closer9] #2545307
09/03/18 07:21 PM
09/03/18 07:21 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
I have one of these from LPW. It hangs lower than stock, but its not too bad
https://www.lpwracing.com/Trans_Pans/Deep_Transmission_Pans.html
1972 Dodge Challenger
Re: Recommend a pan for 727? [Re: closer9] #2545516
09/04/18 08:25 AM
09/04/18 08:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The replacement 518 pan availible from Dorman and other sources is a great value and works well.
Doug
Re: Recommend a pan for 727? [Re: dvw] #2545525
09/04/18 09:45 AM
09/04/18 09:45 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
My old Direct Connection pan works fine !
Re: Recommend a pan for 727? [Re: closer9] #2545541
09/04/18 10:33 AM
09/04/18 10:33 AM
crlush Offline
crlush  Offline
I had the wrong o-ring in my dipstick tube it caused a leak that looked to be coming from the pan (was leaking down then went around where the gasket for oilpan is and would drip in a different spot).
Re: Recommend a pan for 727? [Re: dvw] #2545573
09/04/18 11:28 AM
09/04/18 11:28 AM
BDW Offline
BDW  Offline
Doug
Exactly what I did, was only $35 on Amazon
Dorman # 265-827
These things are simple stamped steel, no reason they should cost $100
Re: Recommend a pan for 727? [Re: BDW] #2545969
09/05/18 01:56 AM
09/05/18 01:56 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i know a guy who had a problem with ford valve covers bending/leaking,he cut out a metal ring the shape pf a gasket out of 1/4 inch steel plate drilled holes for the bolts and bolted it on the top side of the valve cover NOT the gasket side,no more leaks,that should work for a trans pan also,even pressure like a pressure plate will squeeze the gasket/pan uniformly
my ladder of success is missing some rungs
Re: Recommend a pan for 727? [Re: closer9] #2550581
09/16/18 12:06 PM
09/16/18 12:06 PM
SW MO
closer9 Offline OP
closer9  Offline OP
SW MO
I keep forgetting to update, but it's been over a week since I installed the TCI pan and Moroso gasket. So far floor is still dry. 😀 I probably could have made the old pan work with a thick bead of RTV, but I didn't like that idea.
Daily:
'19 Frontier 4WD
Belle:
Other:
Re: Recommend a pan for 727? [Re: closer9] #2550692
09/16/18 05:49 PM
09/16/18 05:49 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Glad to see you gut it fixed. Some of them stamped steel pans leak. The new MP deep ones I have had h=good luck with but changed to thick Cast Aluminium. Since a few others mad the thread into a show and tell here is mine
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
