Recommend a pan for 727?
#2543999
08/31/18 09:49 PM
08/31/18 09:49 PM
Posts: 2,190 SW MO
closer9
SW MO
Can anyone recommend a good trans pan for 727 with a drain plug? I would love to find a cast one, but can't find anything that isn't deeper, and I don't want it hanging any lower.
I bought a thick steel, can't remember the brand, years ago, but put it in storage shortly after. I've had leak problems ever since, and yes it'sthe pan. It's 3/16" and nearly impossible for me to get it flat. I've tried all the gaskets including the reusable 46re.
Daily: '19 Frontier 4WD Belle: '67 Belvedere Convertible, 318/727 in Go ManGo! Other: '64 C10, 283/3 on the tree
Re: Recommend a pan for 727?
[Re: closer9]
#2544018
08/31/18 10:41 PM
08/31/18 10:41 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
5 options at Summitt, none cast because of the stock depth requirement. https://tinyurl.com/y7ck5yegI've used none of them, seems they don't carry the one I used in the past anymore.
[Re: closer9]
#2544023
08/31/18 11:00 PM
08/31/18 11:00 PM
Posts: 2,190 SW MO
closer9
SW MO
I looked at Summit and read all the reviews. Just curious if there was anything else or if anyone had used them.
TCI steel pan seems to have the best reviews. I did see they make a +2 quart aluminum that got good reviews, but still adds 2".
[Re: closer9]
#2544027
08/31/18 11:09 PM
08/31/18 11:09 PM
Posts: 2,190 SW MO
closer9
SW MO
Hmmm... hadn't seen/tried the steel core Moroso gasket. Been reading up on it. Might try it before I give up on this pan. https://www.summitracing.com/parts/mor-93110
[Re: closer9]
#2544032
08/31/18 11:16 PM
08/31/18 11:16 PM
Supercuda
About to go away
About to go away
up yours
I used the MP steel pan and the steel core pan gasket on my 64 300's 727. No issues, once I helicoiled all the stripped out pan bolt holes. I don't know if you eliminated other possibilities for the source of the leak, but there are a number of other areas than can leak and make you think it's the pan. The trickiest one to recognize is the kickdown/shifter shaft seal.
You might consider the 46RE pan, rockauto has them with plug for a reasonable cost, 98 1500 360 V8
[Re: closer9]
#2544038
08/31/18 11:26 PM
08/31/18 11:26 PM
Posts: 2,190 SW MO
closer9
SW MO
Yeah, I've replaced all the seals. It's dry above the gasket. This last time I thought I had it fixed, I just let it idle in neutral to keep leaks from getting blown around.
I'm currently using the 46RE gasket. The rubber strips are very thin.
[Re: closer9]
#2544126
09/01/18 03:22 AM
09/01/18 03:22 AM
RapidRobert
It's 3/16" and nearly impossible for me to get it flat. No way to beat/persuade it flat I am assuming.
[Re: closer9]
#2544136
09/01/18 05:27 AM
09/01/18 05:27 AM
Guitar Jones
The rear band lever pivot shaft is a source of many so called pan leaks. If it's wet at the rear of the pan rail this could be your issue.
[Re: closer9]
#2544281
09/01/18 02:52 PM
09/01/18 02:52 PM
Posts: 2,190 SW MO
closer9
SW MO
Yeah. I did the rear band shaft a few years back, but now feeling kinda stupid. I don't think I've bothered to check if the screws are bottoming out. I think I may get the Morroso gasket and will try it and make sure all the holes are cleaned out. Might go ahead and get the TCI stamped pan while I'm at it.
Thanks, guys.
[Re: dvw]
#2545573
09/04/18 11:28 AM
09/04/18 11:28 AM
Posts: 4,739 Florida
BDW
The replacement 518 pan availible from Dorman and other sources is a great value and works well. Doug Exactly what I did, was only $35 on Amazon Dorman # 265-827 These things are simple stamped steel, no reason they should cost $100
[Re: BDW]
#2545969
09/05/18 01:56 AM
09/05/18 01:56 AM
Posts: 954 garnett kansas
rhad
garnett kansas
i know a guy who had a problem with ford valve covers bending/leaking,he cut out a metal ring the shape pf a gasket out of 1/4 inch steel plate drilled holes for the bolts and bolted it on the top side of the valve cover NOT the gasket side,no more leaks,that should work for a trans pan also,even pressure like a pressure plate will squeeze the gasket/pan uniformly
my ladder of success is missing some rungs
[Re: closer9]
#2550581
09/16/18 12:06 PM
09/16/18 12:06 PM
Posts: 2,190 SW MO
closer9
SW MO
I keep forgetting to update, but it's been over a week since I installed the TCI pan and Moroso gasket. So far floor is still dry. 😀 I probably could have made the old pan work with a thick bead of RTV, but I didn't like that idea.
