Trick Flow 270 OOTB quality????? #2545318
09/03/18 07:38 PM
09/03/18 07:38 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Just got my 270s and was wondering if I need to completely disassemble and check all valve/guide clearances, spring pressures and so on. Can I just check spring pressures on one or two valves on each head?
I will obviously be checking piston to valve, push rod and other clearances as well as rocker arm geometry.
Tell me from experience with Trick Flow heads how yours turned out.
Re: Trick Flow 270 OOTB quality????? [Re: mercman1] #2545322
09/03/18 07:40 PM
09/03/18 07:40 PM
AndyF Offline
AndyF  Offline
They should be ready to go out of the box but if you have the tools it doesn't hurt to pull them apart and check everything. If you don't have the tools to do that job then you have to decide if you're going to take them to a shop or not. I've used a few sets of the Trick Flow heads now and they were all just fine right out of the box.
Re: Trick Flow 270 OOTB quality????? [Re: AndyF] #2545324
09/03/18 07:48 PM
09/03/18 07:48 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Mine were honed just a touch on the guides to my
builders liking , but he said we didnt haave to , but now
Hes happy- he disassembled all , because hes anal..
Re: Trick Flow 270 OOTB quality????? [Re: sogtx] #2545335
09/03/18 08:41 PM
09/03/18 08:41 PM
birdtracker Offline
birdtracker  Offline
I bought the mid level ones good to .680 lift. My installed heights were all over the place, spring pressures were extremely low, and the springs coil binded at .680. The guides and seats were spot on. Check them. Birdtracker
Re: Trick Flow 270 OOTB quality????? [Re: mercman1] #2545376
09/03/18 10:23 PM
09/03/18 10:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I have a set in the shop now........ the guide clearance is def tighter than what I’d prefer to see...... on this set they’re right at .0006”.
Re: Trick Flow 270 OOTB quality????? [Re: mercman1] #2545430
09/03/18 11:30 PM
09/03/18 11:30 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Always assume parts are junk OOTB until proven otherwise. Just because nobody else has had any problems doesn't mean you won't.
Kevin
Re: Trick Flow 270 OOTB quality????? [Re: mercman1] #2545440
09/03/18 11:51 PM
09/03/18 11:51 PM
TN
RRandP92 Offline
RRandP92  Offline
TN
Had mine gone through, guides were tight and everything needed to be cleaned thoroughly.
Re: Trick Flow 270 OOTB quality????? [Re: Twostick] #2545447
09/04/18 12:06 AM
09/04/18 12:06 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Kevin
Remember every week has a monday and a Friday and possibly a thirsty Thursday
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
